- LinuxCNC
- Installing LinuxCNC
- ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
- twoflowers
- Visitor
09 Oct 2020 06:32 - 12 Jul 2021 10:07 #185431
by twoflowers
ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd was created by twoflowers
Images gone - say thanks to CoC policemen. [b]Don't forget: OBEY![/b]
Last edit: 12 Jul 2021 10:07 by twoflowers.
- Thank you received: 2164
09 Oct 2020 06:44 #185432
Replied by Aciera on topic ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
Please excuse my ignorance, but what architecture is this for?
- twoflowers
- Visitor
09 Oct 2020 07:00 #185433
by twoflowers
Replied by twoflowers on topic ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
amd64 (thanks, added it in the description)
09 Oct 2020 09:02 #185447
Hm, interesting. Never heard of that distro, thanks.
- twoflowers
- Visitor
02 Nov 2020 19:47 #188145
by twoflowers
As TDE was updated to 14.0.9 I uploaded a new release (link in 1. posting). I also added Arduino IDE
- Thank you received: 7466
02 Nov 2020 21:27 #188155
Replied by tommylight on topic ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
Gave it a quick run, it works and it is snappy !
- partec
- Thank you received: 27
03 Nov 2020 08:52 #188193
by partec
Replied by partec on topic ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
Danke, interessant und funktioniert, das Desktop Hintergrundbild allein ist einen Blick wert, ich habe auch bei devuan wiki hineingeschaut
nebenbei, ich war etwas erstaunt,
Wilkommen
bei der Oberflächenvorbereitung sollte noch deutsch verbessert werden
Wilkommen
- twoflowers
- Visitor
03 Nov 2020 18:26 - 03 Nov 2020 18:27 #188247
by twoflowers
Good you like it:)
Das TDE Projekt trinitydesktop.org freut sich über jeden, der an der Verbesserung der Übersetzung mitmacht - Kommunikation über die Mailingliste.
Last edit: 03 Nov 2020 18:27 by twoflowers.
- whoppa
08 Dec 2020 07:24 #191391
by whoppa
Replied by whoppa on topic ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
Wow this is great. I installed to a partition on my hard drive. As not so great with linux I struggled a bit to work out how to boot it. Then I found that In my existing install sudo update-grub did the trick. I imported my machine config and its running sweet. Thanks
- Clive S
- Thank you received: 486
08 Dec 2020 12:52 - 08 Dec 2020 18:40 #191413
by Clive S
I have tried this ISO and it seems to be snappy as Tom says.
But I am having trouble to get it to boot from the HD. I can see all the system files on the drive etc.
Can you please help with getting it to boot from the sata drive.
Edit: I copied the ISO to a USB with Win32DiskImager to make it bootable
Edit: If I install mint on another partition on the hard drive and use the boot menu on that I can then pick the appropriate boot to boot the the Exegnulinux system.
But I don't seem to be able to get the grub on its own.. I get the error PXE-E53 No boot file received
Replied by Clive S on topic ISO to test: Exegnulinux remasterd with LinuxCNC, a lots of tools and no systemd
(Note: Check GRUB settings)
Last edit: 08 Dec 2020 18:40 by Clive S.
- LinuxCNC
Time to create page: 3.096 seconds
