linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
- twoflowers
- Visitor
03 Feb 2021 09:44 - 03 Feb 2021 09:45 #197531
by twoflowers
Replied by twoflowers on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
Exactly that image works here. But as I said, I did not put it on the SD-card but a USB thumbdrive plugged into the USB3 port. When I remove the 3GB limit, it does not boot (USB is unavailable), but otherwise it just works.
Oh, and it does not boot on the RPI3+
Last edit: 03 Feb 2021 09:45 by twoflowers.
- twoflowers
- Visitor
04 Feb 2021 07:58 #197622
by twoflowers
... but there is something fishy with the kernel. I see these in the logfile - and I can imagine that you cannot boot reliably from mmc:
[ 77.284159] mmc0: Timeout waiting for hardware cmd interrupt.
[ 77.289904] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 77.296338] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 77.302771] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 77.309204] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 77.315637] mmc0: sdhci: Present: 0x1fff0001 | Host ctl: 0x00000001
[ 77.322070] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 77.328502] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x0000f447
[ 77.334935] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 77.341367] mmc0: sdhci: Int enab: 0x00ff1003 | Sig enab: 0x00ff1003
[ 77.347800] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 77.354232] mmc0: sdhci: Caps: 0x45ee6432 | Caps_1: 0x0000a525
[ 77.360664] mmc0: sdhci: Cmd: 0x00000502 | Max curr: 0x00080008
[ 77.367096] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 77.373529] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 77.379961] mmc0: sdhci: Host ctl2: 0x00000000
[ 77.384396] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
[ 77.390828] mmc0: sdhci: ============================================
- twoflowers
- Visitor
04 Feb 2021 17:27 #197665
by twoflowers
Followup: I compiled a kernel without MMC, but that does not only disable MMC, it also disables USB, so no win there.
- Paraquatz
12 Apr 2021 22:06 #205740
by Paraquatz
Replied by Paraquatz on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
First, following the peremptory shout from Linuxcnc: /quote: 'This SD image is reported not to work with the Raspberry Pi4 8GB model. Note also that this version of the SD image limits available memory to 3GB as this is necessary to persuade it to run with both WiFi and USB working on some versions of the Pi. You can experiment with removing this limit by editing the config-rt.txt file in the boot directory.'
Thus I've corrected a config-rt.txt extending 3,072 up to the 8,192 which is translation for 8 Gigs, I've noticed /boot/config.txt has a reference on it so far.
Being an outright noob in Pis (native OS X user since 1999) so I made a clean copy of Rasp OS with Rasp Pi Imager firsthand, which later has happened to be much of avail.
After I found when booting up from solely SD image with my exact memory in the above mentioned file USB appears completely irresponsive. Once I've rolled back all changes to the 3,072 I have achieved a booting of freshly installed Pi OS with a LinuxCNC precompiled and present in the Pi menu.
12 Apr 2021 22:15 #205742
Replied by andypugh on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
I am not clear. Are you saying that the 3Gb limit is not necessary, or that it is necessary?
- Paraquatz
12 Apr 2021 22:30 - 13 Apr 2021 05:19 #205745
by Paraquatz
For in my case it was imperatively necessary. Yes, one more thingy please do not pay any heed to any actual software start failure, for me it had started working with 'legacy lathe' preconfig from the 3rd time, yet it does comparably stable and it generates report files storing it at /tmp in your /pi home dir. Yes and no browser will be at start as reported, never tried to fix it yet, though. Please check out how its working in the overall:
To manipulate vector graphics in the prog please make sure to have a 3 buttons mouse at a hand, a stock Rasp Pi wheeled one just does the whole trick very well for me.
Last edit: 13 Apr 2021 05:19 by Paraquatz. Reason: adding vid
- activa73
14 Apr 2021 19:35 #205933
by activa73
Replied by activa73 on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
Hello,
I have install Linuxcnc-2.8.1-pi4.img on my pi4 4 Go.
I have one issue:
Debug file information:
Note: Using POSIX realtime
HAL_PI_GPIO: ERROR: board revision 6 not supported
hal_pi_gpio: rtapi_app_main: Invalid argument (-22)
./aselec-jeulin_microtour.hal:21: waitpid failed /usr/bin/rtapi_app hal_pi_gpio
./aselec-jeulin_microtour.hal:21: /usr/bin/rtapi_app exited without becoming ready
./aselec-jeulin_microtour.hal:21: insmod for hal_pi_gpio failed, returned -1
1791
Stopping realtime threads
Unloading hal components
The issue come from HAL_PI_GPIO where my rpi 4 board was not support.
But the issue come from more deeper, in cpuinfo.c my rpi4 revision C03114 was present in file from 15 january and I suppose that this img file Linuxcnc-2.8.1-pi4.img was created before this modification.
I think make a new img file with actual source can solve the issu, but I haven't the knowledge to built this new version.
Do you know who can help me to built a new version please?
BR
I have one issue:
1791
BR
- cakeslob
- Thank you received: 280
15 Apr 2021 01:02 #205961
by cakeslob
Replied by cakeslob on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
You could probably just update instead of build a whole new one ? Or does he have to rebuild to apply the changes to the driver section?
Might be less help than intended, but I usually do it this way, using this as a guide
forum.linuxcnc.org/32-documents/34495-in...al-version-git-clone
full disclosure i dont know how to use the terminal file thing or how to do a global install. i also have to do it twice, because the first time doesnt work. the image looks like it was made after the update but I dont know how these things work. I was just curious about the revision numbers.
Also , the compute modules use a different revision code it seems . a/b/c/d03140
git clone https://github.com/LinuxCNC/linuxcnc.git emc2
cd emc2
dpkg-checkbuilddeps
cd
cd emc2/debian
./configure uspace
cd
cd emc2/src
./autogen.sh
./configure
make -j4
##check it has 191/191deps anbd 206/206deps or something like that. dont paste this into terminal##
sudo make setuid
cd
cd emc2/scripts
./rip-environment
./linuxcncfull disclosure i dont know how to use the terminal file thing or how to do a global install. i also have to do it twice, because the first time doesnt work. the image looks like it was made after the update but I dont know how these things work. I was just curious about the revision numbers.
- tjtr33
- Thank you received: 54
15 Apr 2021 13:54 #206009
by tjtr33
Replied by tjtr33 on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
Just in case the normal debian user is here
and sees the rpi imager is for ubuntu...
the github source
github.com/raspberrypi/rpi-imager
has details how to build raspberry pi imager for debian
also for Fedora/RHEL/CentOS Linux
hth
tomp
the github source
hth
tomp
- tjtr33
15 Apr 2021 14:21 - 15 Apr 2021 14:35 #206012
by tjtr33
I get erors building on debian 9 after deps installed
tomp ( who will try with dd )
Generating qrc source rpi-imager_automoc.dir/qrc_translations_62PNPOSFFYCW6J.cpp
RCC: Error in '/media/tomp/toms4T/2021/misc-15apr2021/misc-emc/rpi4-andySezThisJustWorks/rpi-imager-for-debian/rpi-imager-qml/obj-x86_64-linux-gnu/translations.qrc': Cannot find file 'rpi-imager_de.qm'
AUTORCC: error: process for rpi-imager_automoc.dir/qrc_translations_62PNPOSFFYCW6J.cpp failed:
rcc failed...tomp ( who will try with dd )
Last edit: 15 Apr 2021 14:35 by tjtr33.
Time to create page: 1.540 seconds
