linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
- antage
18 Jan 2021 06:37 #195778
by antage
Replied by antage on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
It early used total_mem hack to limit DMA address zone (DMA safe zone must be <3GB address). But 4.19 has all fixes for these issues for 32-bit and 64-bit kernel. It may be another issue with >3GB but I can't find it in raspberrypi/linux github issues.
18 Jan 2021 19:21 - 18 Jan 2021 19:29 #195852
Replied by andypugh on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
Well, I am confused now.
Intending to investigate the effect of limiting memory to 3GB I made a new standard 32-bit SD card image, booted my new 2GB Pi4 (bought specifically to debug this reported issue) and followed the instructions here in the LinuxCNC docs:
linuxcnc.org/docs/2.8/html/getting-start...lling_on_raspbian_10
Contrary to the reports in this and other threads, it all "just worked".
I moved the SD card to my Pi400, and that worked, and then to my old 4GB Pi4, and that worked.
Is there _actually_ a problem?
Also, can we move this discussion to one thread, ie this one:
forum.linuxcnc.org/9-installing-linuxcnc...-work?start=0#194602
Last edit: 18 Jan 2021 19:29 by andypugh.
- johnp
18 Jan 2021 22:50 - 18 Jan 2021 22:50 #195868
by johnp
I can only get USB working by setting total_mem to a maximum of 3072.
I can do this before or after installing the realtime kernel and back an forth. Anytime total_mem is greater than 3072 my USB stops working.
Replied by johnp on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
On my 8GB Pi4, after following the instructions hereIs there _actually_ a problem?
Sounds reasonable as the 2GB bit in this thread title is misleading.Also, can we move this discussion to one thread, ie this one:
Last edit: 18 Jan 2021 22:50 by johnp.
- bdp32
29 Jan 2021 10:51 #197070
by bdp32
Replied by bdp32 on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
I'd just like to say I've just experienced the No USB with a 2GB pi 4
This is my second pi 4, the first just worked. However this second pi, I took it straight out of the box and put a linuxcnc image in it straight away, the first one I had used for other things first. Thinking that this was the issue I booted a standard raspbian image which worked as expected. Rebooted with LinuxCNC image, still no USB. So can confirm that 2GB is affected.
I will troubleshoot and see if I can work out what's going on.
29 Jan 2021 11:03 #197071
_Which_ LinuxCNC image?
Have you tried linuxcnc-2.8.1-pi4.img ?
- jfselcnc
30 Jan 2021 12:15 #197169
by jfselcnc
Replied by jfselcnc on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
Dear andypugh,
I have experienced the same issue with no USB oder Wifi with a 4G raspi 4. I have used the 2.8.0 img that was linked directly on the entry page (sorry, didn't even get as far as your getting started page). Here I had to add the 3GByte limit and it worked just fine.
Is there any advantage of now using the new 2.8.1 img? I'd rather not setup everything again, if there is not a major advantage. I am up and running with 2.8.0 and all online updates (with 3G limit of course).
Thanks for the linuxcnc image!
PS: I am all new to CNC and will build my CNC-Dötzchen in May 2021 - until then I am practicing CAD
- so no experience and CNC setup yet, just prep work.
30 Jan 2021 12:27 #197171
Not if what you have is working.
The changes include a kernel version that works with the variants that have no eeprom for the USB system and the 4GB limit pre-applied.
Is there any advantage of now using the new 2.8.1 img? .
The following user(s) said Thank You: jfselcnc
- bdp32
01 Feb 2021 09:04 #197310
by bdp32
I hadn't seen that, I was still using 2.8.0, it worked fine with my earlier pi4...
Just found linuxcnc-2.8.1-pi4.img and it seems to work perfectly, thank you
- twoflowers
- Visitor
03 Feb 2021 03:13 #197527
by twoflowers
Replied by twoflowers on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
I have just tested the SD image on my new RPi400. Lateny (Servo+base) is ~ 75000 as it comes out of the box.
Now I moved it from SD to a 8GB Kingston USB3 thumbdrive - write access is a bit on the slow side. I moved /var/tmp /tmp and /var/log to tmpfs, swapped from Debian to Devuan, killed anything GNOME and installed TDE. This brought latency down to 65000.
Now I disabled BT + WIFI + audio. Latency is <50000 after an hour testing.
03 Feb 2021 03:30 #197529
_Which_ SD image?
I found that Linuxcnc-2.8.1-pi4.img didn't work on my Pi400.
_Which_ SD image?
