linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
- idea
28 Oct 2020 13:08 - 09 Nov 2020 13:59 #187558
by idea
linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB was created by idea
So, I found that the image for the raspberry pi on linuxcnc.org/downloads/ has an issue with no USB connectivity on the 8GB Pi 4 boards.
The image boot through to the desktop, but USB keyboard and mouse do not function. And because it is a loaded image there is no chance to set it up for wifi and remote connection to enable access.
I made a comment here; forum.linuxcnc.org/9-installing-linuxcnc...4-tutorial?start=140
And someone else noticed the same issue; forum.linuxcnc.org/9-installing-linuxcnc...ial?start=110#179461
But I thought it better to pull out to a separate thread.
Last edit: 09 Nov 2020 13:59 by idea.
- idea
28 Oct 2020 13:32 - 28 Oct 2020 17:53 #187568
by idea
Replied by idea on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 8GB
So no issues with plain raspbian [2020-08-20-raspios-buster-armhf.img], just linuxcnc image [linuxcnc-2.8.0-pi4.img]
I also get the following errors with linuxcnc that do not come up with raspbian;
kvm [1]: Error, CPU 0 not supportd!
xhci_hcd 0000:01:00.0: can't setup: -110
xhci_hcd 0000:01:00.0: init 0000:01:00.0 fail, -110
Some possibly related links
www.cnx-software.com/2019/11/04/raspberr...ork-on-ubuntu-19-10/
linux.debian.bugs.dist.narkive.com/Uz3Xr...-raspberry-pi-4b-8gb
leo3418.github.io/2020/09/20/raspi4-fedora-usb-simple.html
leo3418.github.io/2020/09/21/raspi4-fedora-usb-complex.html
bugs.launchpad.net/ubuntu/+source/linux-raspi2/+bug/1848790
Last edit: 28 Oct 2020 17:53 by idea.
- rsaccon
29 Oct 2020 12:30 #187679
by rsaccon
Replied by rsaccon on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 8GB
My first post here, hi all. I ran into the same issue. I followed the instructions at linuxcnc.org/docs/2.8/html/getting-start...etting-linuxcnc.html (7.3. Installing on Raspbian 10) for every Kernel of the 4.19.XX series and always after replacing with the patched realtime Kernel linux-image-4.19.71-rt24-v7l+ after reboot I still could log in via SSH, but anything connected via UBS (in my case the touch function of a touchscreen, and also mouse and keyboard) did not work anymore. I also tried the manual replacement of the Kernel with a precompiled realtime version from gnipsel.com/linuxcnc/uspace/rpi4-rt.html - same problem.
- inoxix
02 Nov 2020 19:46 #188143
by inoxix
Replied by inoxix on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 8GB
Hi all,
Just ran into the same problem. All fine with a Raspi 4, 4GB. When I move the SD card to the 8GB no keyboard and mouse.
- inoxix
03 Nov 2020 07:55 - 03 Nov 2020 08:28 #188186
by inoxix
Hi
I did a side by side comparison of a Pi4 with 4GB and 8GB. I modified the image in order to get ssh from the first boot. Both have a mouse connected and no screen.
The dmesg shows that on the 8GB the xHCI could not get activated (see line 142/142. Later this device is mentioned as the USB Host controller.
This problem appears only with the linuxcnc image.
Board version RPi4 4GB:
Hardware : BCM2835
Revision : c03111
Serial : 10000000ed832f24
Model : Raspberry Pi 4 Model B Rev 1.1
Board version RPi4 8GB:
Hardware : BCM2835
Revision : d03114
Serial : 1000000005046c7f
Model : Raspberry Pi 4 Model B Rev 1.4
The same devices booting Raspberry Pi OS / Debian Buster:
BR
Tom
Hardware : BCM2835
Revision : c03111
Hardware : BCM2835
Revision : d03114
BR
Tom
Last edit: 03 Nov 2020 08:28 by inoxix.
- Kiddekanin
- Thank you received: 3
09 Nov 2020 06:25 #188724
by Kiddekanin
Replied by Kiddekanin on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 8GB
Same issue goes for the Raspberry Pi 4 Model B - 2 GB
No USB after boot
No USB after boot
- idea
09 Nov 2020 17:29 #188768
by idea
Replied by idea on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
I found the following at - wiki.debian.org/RaspberryPi4
- USB doesn't work up to kernel 5.7 for the hardware variant of PI4 with 8GB RAM
- This issue has a fix in kernel 5.8 (currently in experimental): lkml.org/lkml/2020/5/5/998
But I'm not clear if the build image here is running debian
- cakeslob
- Thank you received: 280
10 Nov 2020 01:12 #188831
by cakeslob
Replied by cakeslob on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
so no usb period after startup? do they power up at all?
i havent tried it on my 8gb yet, but here is what rpi forum says, seems related to the topic at hand
www.raspberrypi.org/forums/viewtopic.php?t=287340
www.raspberrypi.org/forums/viewtopic.php?t=285563
- idea
10 Nov 2020 02:51 #188837
by idea
My 8GB powers up all the way through to the desktop, just fails to start USB during boot (see errors logged above), so no keyboard / mouse.
- BrettB
12 Nov 2020 20:33 #189150
by BrettB
Replied by BrettB on topic linuxcnc-2.8.0-pi4.img - no USB on raspberry pi 4 - 8GB & 2GB
Hi all,
Having the same issue with my pi4 8GB. No USB after boot.
What's the current workaround? I'm very new to LinuxCNC so this also my first install.
Kind regards,
Brett.
Kind regards,
Brett.
Time to create page: 0.149 seconds
