Raspberry Pi 4 Tutorial - fatal error
- lumberjack_jeff
20 Oct 2020 04:58 - 22 Oct 2020 03:24 #186648
by lumberjack_jeff
Replied by lumberjack_jeff on topic Raspberry Pi 4 Tutorial
Thanks for the tutorial. I followed the tutorial in headless mode (ssh); ran into a problem. After building the preempt rt kernel, DEPMOD reported a different version (I didn't write it down). After installation and subsequent edit of the /boot/cmdline.txt to append the text, I did reboot, but the device is no longer accessible to the network - not via wifi and not via ethernet. Suggestions?
on edit:
Obtained a micro hdmi adapter so as to view the boot process, the device shuts down on a kernel panic.
on edit:
Last edit: 22 Oct 2020 03:24 by lumberjack_jeff. Reason: new info
- idea
28 Oct 2020 01:55 - 28 Oct 2020 12:55 #187488
by idea
Replied by idea on topic Raspberry Pi 4 Tutorial - fatal error
I'm also getting this same issue of no USB mouse / keyboard (all types) with my 8Gb version - straight from fresh SD card image - linuxcnc-2.8.0-pi4.img
Any ideas of how to fix?
This is not a power issue (that has been previously noted), running of 7A SMPS and also tried with 20Ahr battery pack with same result.
When plugging in usb mouse, the red sensor led lights up briefly before going out (all 4 usb ports).
Unable to set up remote access so impossible to generate any kind of dump.
Last edit: 28 Oct 2020 12:55 by idea.
28 Oct 2020 13:07 #187557
Replied by andypugh on topic Raspberry Pi 4 Tutorial - fatal error
There are some ideas here, but they rely on SSH being available.
Do you have the same problem with a standard Raspbian install, or is it just the LinuxCNC image?
- idea
28 Oct 2020 13:15 #187561
by idea
i've made a separate thread to avoid clogging this one up
forum.linuxcnc.org/9-installing-linuxcnc...-on-raspberry-pi-8gb
- Kiddekanin
- Thank you received: 3
09 Nov 2020 10:17 #188731
by Kiddekanin
Replied by Kiddekanin on topic Raspberry Pi 4 Tutorial - fatal error
I'm also getting this same issue of no USB mouse / keyboard (all types) with my 2Gb version - straight from fresh SD card image - linuxcnc-2.8.0-pi4.img
"Do you have the same problem with a standard Raspbian install, or is it just the LinuxCNC image?"
Raspbian works fine with keyboard and mouse. So it seems that it is "just the LinuxCNC image"
I will try a 4GB hence it seems to be working straight away.
- Kiddekanin
12 Nov 2020 05:21 #189087
by Kiddekanin
Bought the 4gb version, and it booted right up
14 Jan 2021 17:13 #195342
Can those with this problem please state exactly which model of Pi they are using?
One possible problem is that the 8GB Pi needs a 64bit kernel if it is going to address more than 4GB.
- ACKNAC
16 Feb 2021 20:26 #199105
by ACKNAC
Replied by ACKNAC on topic Raspberry Pi 4 Tutorial - fatal error
I have both a Rpi 4 B 2G & Rpi 4 8G and have this problem. So far I have tried using the 2.80 & 2.81 Images and get the same results no matter which Pi or version I use.
17 Feb 2021 12:55 #199150
Can you state exactly what problem you have (this is a long thread), and how it becomes evident?
I have a Pi42GB that I bought specifically for testing the SD card image, and it works for me.
- jaro_p
- Thank you received: 5
19 Feb 2021 13:52 #199428
by jaro_p
Replied by jaro_p on topic Raspberry Pi 4 Tutorial - fatal error
I have the same problem with both versions, so 2.8 and 2.81.
I tried it on Raspberry pi 400 and RPi 4B+ 4Gb.
Either the system freezes immediately after the restart following the notification: resize file system.
This is preceded by a message: Error: cpu 0 not supported
Or the system freezes as soon as the desktop is displayed.
