pauluzs wrote: Have seen that repoitory only thing : Isn't the main Pi repository 32 bit?
The Pi4 is arm64 bits and i wanted to skip compiling a whole new kernel for that and rather take the shortcut.
uname -a
Linux rpi4-20201112 5.9.0-0.bpo.5-rt-arm64 #1 SMP PREEMPT_RT Debian 5.9.15-1~bpo10+1 (2020-12-31) aarch64 GNU/Linux
tried that at first also with a fail, seems you need a running arm64 kernel to install the rt-kernelandypugh wrote:
The Pi repository can be compiled for any architecture (including RISC and MIPS). I compiled an arm64 kernel yesterday using it, but it won't install as even a Pi set up with a (stock) 64 bit kernel has a 32-bit userspace and rejects an arm64 kernel deb.
yes i did manage to compile linuxcnc master from source and run it on that kernel
LinuxCNC does not really benefit from 8GB of memory. (And, as the LinuxCNC armhf image is 32 bits, couldn't use it anyway)
uname -a
Does Linuxcnc install and run (in realtime) on that system?
My understanding (possibly wrong) is that the Pi kernel has significant differences from a vanilla arm kernel, which is why we have been working with the forked Pi kernel sources.
pauluzs wrote:
yes i did manage to compile linuxcnc master from source and run it on that kernelDoes Linuxcnc install and run (in realtime) on that system?
