EDIT: Apologies for the redundant post, the 2.8.1 image works for me.
linuxcnc.org/downloads/
still only shows 2.8.0 which is where the confusion occured. I found the 2.8.1 image in the end at
linuxcnc.org/docs/2.8/html/getting-start...tml#_normal_download
Hi I'm having the same issue (no mouse, no keyboard) with the raspberry pi 4b 4Gb model.
I'm able to ssh in to the pi, here is the output for uname -a:
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.71-rt24-v7l+ #1 SMP PREEMPT RT Fri Jan 1 21:15:16 GMT 2021 armv7l GNU/Linux
Here is also the output of lsmod just incase it helps:
pi@raspberrypi:~ $ lsmod
Module Size Used by
bnep 20480 2
hci_uart 40960 1
btbcm 16384 1 hci_uart
serdev 20480 1 hci_uart
bluetooth 380928 24 hci_uart,bnep,btbcm
ecdh_generic 28672 1 bluetooth
8021q 32768 0
garp 16384 1 8021q
stp 16384 1 garp
llc 16384 2 garp,stp
brcmfmac 315392 0
brcmutil 20480 1 brcmfmac
sha256_generic 20480 0
cfg80211 634880 1 brcmfmac
vc4 176128 0
rfkill 28672 6 bluetooth,cfg80211
bcm2835_codec 36864 0
drm_kms_helper 184320 1 vc4
bcm2835_v4l2 45056 0
v4l2_mem2mem 24576 1 bcm2835_codec
bcm2835_mmal_vchiq 32768 2 bcm2835_codec,bcm2835_v4l2
v4l2_common 16384 1 bcm2835_v4l2
v3d 65536 0
snd_soc_core 184320 1 vc4
videobuf2_dma_contig 20480 1 bcm2835_codec
videobuf2_vmalloc 16384 1 bcm2835_v4l2
snd_compress 20480 1 snd_soc_core
gpu_sched 28672 1 v3d
videobuf2_memops 16384 2 videobuf2_dma_contig,videobuf2_vmalloc
snd_bcm2835 24576 1
snd_pcm_dmaengine 16384 1 snd_soc_core
videobuf2_v4l2 24576 3 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem
raspberrypi_hwmon 16384 0
syscopyarea 16384 1 drm_kms_helper
snd_pcm 98304 4 vc4,snd_pcm_dmaengine,snd_bcm2835,snd_soc_core
drm 442368 5 v3d,vc4,gpu_sched,drm_kms_helper
hwmon 16384 1 raspberrypi_hwmon
videobuf2_common 45056 4 bcm2835_codec,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
sysfillrect 16384 1 drm_kms_helper
drm_panel_orientation_quirks 16384 1 drm
sysimgblt 16384 1 drm_kms_helper
snd_timer 32768 1 snd_pcm
videodev 200704 6 bcm2835_codec,v4l2_common,videobuf2_common,bcm2835_v4l2,v4l2_mem2mem,videobuf2_v4l2
fb_sys_fops 16384 1 drm_kms_helper
vc_sm_cma 36864 1 bcm2835_mmal_vchiq
snd 73728 7 snd_compress,snd_timer,snd_bcm2835,snd_soc_core,snd_pcm
media 36864 3 bcm2835_codec,videodev,v4l2_mem2mem
rpivid_mem 16384 0
uio_pdrv_genirq 16384 0
fixed 16384 0
uio 20480 1 uio_pdrv_genirq
i2c_dev 20480 0
ip_tables 24576 0
x_tables 32768 1 ip_tables
ipv6 454656 30
I'm happy to help you get any more information
