Last update of LinuxCNC Raspberry Pi4 USB does not work
5 years 9 months ago #196834 by alkabal
Hi
Today test with brand new pi 400 using :
www.linuxcnc.org/temp/image_2021-01-20-linuxcnc-pi4-3G.zip
No wifi detected.
5 years 9 months ago #196859 by andypugh
kramerda wrote: Quick ? Andy....what process did u use to create the .3H image zip file?
I use: github.com/LinuxCNC/pi-gen
But it relies on all the packages being available on a repository, and just assembles an SD image to a repository.
git clone it, edit the "stage" files, and then "sudo ./build.sh". A base and light image will appear in the "deploy" directory some considerable time later.
5 years 9 months ago #196860 by andypugh
alkabal wrote: Today test with brand new pi 400 using :
www.linuxcnc.org/temp/image_2021-01-20-linuxcnc-pi4-3G.zip .
Yes, Pi400 remains a problem. (I have one)
But the Pi400 _probably_ isn't a good CNC controller candidate?
5 years 9 months ago #196862 by andypugh
The LinuxCNC docs now point at a (renamed) version of the 3G limited image, with warnings that it is known to not work on all variants.
linuxcnc.org/docs/2.8/html/getting-start...tml#_normal_download
5 years 9 months ago #196867 by rsaccon
andypugh, according to my latest test (see my previous post), the www.linuxcnc.org/temp/image_2021-01-20-linuxcnc-pi4-3G.zip does work on Pi 8GB. Wlan and USB are ok.
5 years 8 months ago #199691 by andypugh
There might be a fix in the kernel discussed here:
github.com/kdoren/linux/discussions/3#discussioncomment-389373
There is a downloadable kernel image deb here:
github.com/kdoren/linux/releases/tag/5.10.16-rt30
(I have not tried it)
Time to create page: 0.121 seconds
