- Thank you received: 234
Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
- Bari
5 years 5 months ago #209450
by Bari
Replied by Bari on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
Post your dmesg after running the test suite but before rebooting.
You don't have to recompile.
I will not likely look at it for 12+ hours from now.
- Arthur_L
5 years 5 months ago - 4 years 9 months ago #209451
by Arthur_L
Replied by Arthur_L on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
xxx@xxx:/usr/realtime/testsuite$ sudo ./run
[sudo] password for bodor:
.runinfo is /usr/realtime/testsuite/.runinfo
No RTAI modules loaded.
Running insmod on /usr/realtime/testsuite/.runinfo...
CANNOT FIND MAILBOX
Cleaning up...
RTAI successfully unloaded.
Removing /tmp/runinfo...
Done.
CANNOT FIND MAILBOX
Cleaning up...
Done.
Last edit: 4 years 9 months ago by Arthur_L.
- Bari
5 years 5 months ago #209452
by Bari
Run: $ dmesg
It will likely be a big text file that you can add as an attachment to the post here.
Run: $ dmesg
- Arthur_L
5 years 5 months ago - 4 years 9 months ago #209453
by Arthur_L
dmesg
[ 0.000000] microcode: microcode updated early to revision 0x28, date = 2019-11-12
[ 0.000000] Linux version 4.19.152-rtai-amd64 (root@xxx) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.12)) #1 Wed May 19 11:14:24 CST 2021
- Arthur_L
5 years 5 months ago #209454
by Arthur_L
dmesg
- Arthur_L
5 years 5 months ago #209456
by Arthur_L
Sorry...dmesg file
Time to create page: 0.917 seconds
