Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
- Arthur_L
5 years 5 months ago #210333
by Arthur_L
Replied by Arthur_L on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
yes! I using the NTULINUX version. I don't know why?
5 years 5 months ago #210334
Replied by andypugh on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
The NTULINUX version is better-integrated with LinuxCNC. I would stick with it.
But you might need to install musl (and maybe musl-dev)
packages.debian.org/source/buster/musl
- Arthur_L
5 years 5 months ago #210415
by Arthur_L
Do I need to install musl (and maybe musl-dev)
packages? debian.org/source/buster/musl
This is the option that needs to be set when compiling RTAI? After I make menuconfig, there is no function library set in it. Which option is it?
5 years 5 months ago #210474
I think that you should just need to install musl and musl-dev
(sudo apt-get install musl musl-dev)
That might make the error message go away. Or you might need to recompile RTAI.
Time to create page: 0.699 seconds
