Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
- Arthur_L
5 years 5 months ago #209591
by Arthur_L
Replied by Arthur_L on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
I used the default path to compile and install RTAI, isn't it /usr/realtime? How to find the actual path to the rtai modules?As the same time ,thank all of you very much for the contribution, I feel linuxcnc is very very great!
- BeagleBrainz
- Visitor
5 years 5 months ago #209594
by BeagleBrainz
Replied by BeagleBrainz on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
just have a look around /usr/realtime
- Arthur_L
5 years 5 months ago #209599
by Arthur_L
This is the linuxcnc configuration information and compilation information
- Arthur_L
5 years 5 months ago - 5 years 5 months ago #209600
by Arthur_L
This is the linuxcnc configuration information and compilation information? Is my rtai still incorrect? Why is there such a thing as pcl720?
Last edit: 5 years 5 months ago by Arthur_L.
- phillc54
- Thank you received: 2100
5 years 5 months ago #209603
by phillc54
github.com/LinuxCNC/linuxcnc/blob/master.../drivers/pcl720.comp
Replied by phillc54 on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
Arthur_L wrote: This is the linuxcnc configuration information and compilation information? Is my rtai still incorrect? Why is there such a thing as pcl720?
The following user(s) said Thank You: Arthur_L
- BeagleBrainz
- Visitor
5 years 5 months ago - 5 years 5 months ago #209604
by BeagleBrainz
It's a card supported by Linuxcnc.
From
"your_linuxcnc_base_dir"/src/hal/drivers/pcl720.comp
component pcl720 """Driver for the Advantech PCL 720 card.""";
description """This driver supports the Advantech PCL720 ISA card. It might
work with the PCI version too, but this is untested.
It creates hal pins corresonding to the digital inputs and outputs, but does
not support the the counters/timers.""";
It wouldn't be a gcc 5.4 issue ?
From
Last edit: 5 years 5 months ago by BeagleBrainz.
Time to create page: 1.037 seconds
