Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
- Arthur_L
5 years 5 months ago #210188
by Arthur_L
Replied by Arthur_L on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
When running runtests, the following errors appear. Do these errors affect the running of linuxcnc?
- Arthur_L
5 years 5 months ago #210189
by Arthur_L
Hi,Andy. When running runtests, the following errors appear. Do these errors affect the running of linuxcnc?
5 years 5 months ago #210260
Replied by andypugh on topic Compile Linux Kernel ,RTAI and LinuxCNC from Source Code
/home/bodor/Downloads/linuxcnc/tests/realtime-math
Looks worrying.
Which maths library did you build in to RTAI? I have tried both musl (as recommended by Paulo) and the {other one} recommended by Alec.
Looks worrying.
- Arthur_L
5 years 5 months ago #210291
by Arthur_L
what is the meaning of "Which maths library did you build in to RTAI?"
This is the option that needs to be set when compiling RTAI? After I make menuconfig, there is no function library set in it. Which option is it? Can you describe it in more detail? Thanks
5 years 5 months ago #210317
Have a look at RTAI/src.math/README.KLIBM
Depending on the version you are using it might not need any config.
5 years 5 months ago #210318
Time to create page: 0.514 seconds
