LinuxCNC on Raspberry Pi 4
- knipknap
- Thank you received: 6
26 Feb 2022 05:19 #235841
by knipknap
LinuxCNC on Raspberry Pi 4 was created by knipknap
Using the following download:
Any workaround for that one, apart from setting up Raspbian/Debian from scratch?
- LinuxCNC 2.8.1 Raspberry Pi OS based on Debian 10 Buster
- Online
- Thank you received: 7504
26 Feb 2022 06:27 #235844
Replied by tommylight on topic LinuxCNC on Raspberry Pi 4
I was sure there is no RPI 4 with 1GB of ram, i was wrong
First result sheds some light
www.google.com/search?q=rpi4+versions&so...oAEB&sclient=gws-wiz
- knipknap
26 Feb 2022 14:40 #235871
by knipknap
Replied by knipknap on topic LinuxCNC on Raspberry Pi 4
Yeah, and it's the only model available for sale anywhere at the moment :-/
- elovalvo
- Thank you received: 127
28 Feb 2022 01:59 - 28 Feb 2022 02:08 #235994
by elovalvo
You can try it this way:
1) download and install the legacy version of RaspiOS
downloads.raspberrypi.org/raspios_oldsta...ios-buster-armhf.zip
2) apply the procedure to install the kernel PREEMPT_RT (32 bit)
github.com/kdoren/linux/releases/tag/rpi_5.10.74-rt54
3) using the gdebi utility install Linuxcnc 2.8.2 from .deb-packages available
buildbot.linuxcnc.org/dists/buster/2.8-r...g68f883b96_armhf.deb
Replied by elovalvo on topic LinuxCNC on Raspberry Pi 4
[*]LinuxCNC 2.8.1 Raspberry Pi OS based on Debian 10 Buster
I flashed an SD card and put it into my Raspberry Pi 4. It doesn't boot, instead showing the following error: "This board requires newer software". (Screenshot attached)
Last edit: 28 Feb 2022 02:08 by elovalvo.
- Deadtoxxic
11 Mar 2022 14:55 #236959
by Deadtoxxic
Replied by Deadtoxxic on topic LinuxCNC on Raspberry Pi 4
Hi All,
I also faced with this when iam using "LinuxCNC 2.8.1 Raspberry Pi OS based on Debian 10 Buster", but on 4GB version of RPI4.
I tried with two different SD car, with one USB flash drive, and with external SSD, but same result unfortunatelly.
Apart from everything, somebody have any clue what the problem?
Following elovalvo:
1. I tried to install a PREEMPT_RT kernel, but i am stuck with that.
2. Buildbot: When i want to reach this page, i recieved this message: "this site can’t be reached"
How should i proceed?
Thank you in advance!
Following elovalvo:
14 Mar 2022 19:13 - 14 Mar 2022 19:14 #237269
Replied by andypugh on topic LinuxCNC on Raspberry Pi 4
It's a bit late here now, but I would suggest starting with a standard 64-bit Raspbian install then searching for a packaged RT kernel.
I think it will probably be this one: packages.debian.org/buster/linux-image-rt-arm64
If you find one then the next step is to install is (sudo apt-get installl linux-image....... ) then compile LinuxCNC from source. (As the buildbot is only making 32-bit arm-hf images)
sudo apt-cache search linux-image*I think it will probably be this one: packages.debian.org/buster/linux-image-rt-arm64
Last edit: 14 Mar 2022 19:14 by andypugh.
- elovalvo
15 Mar 2022 03:02 - 15 Mar 2022 03:03 #237299
by elovalvo
From the photo you uploaded it seems that there is a problem at startup because the SD is not recognized and tries to boot from USB.
My suggestion is to download the full image (Raspbian Buster 64 + LinuxCNC 2.8.2) from this link
drive.google.com/file/d/1sdFvmJx439lZQsq...jQE/view?usp=sharing
and use the Raspberry Pi Imager
www.raspberrypi.com/software/
to write to an SD, avoiding booting from external USB.
Hi All,
Following elovalvo:
Last edit: 15 Mar 2022 03:03 by elovalvo.
- Elco
- Thank you received: 3
17 Mar 2022 17:25 #237576
by Elco
Replied by Elco on topic LinuxCNC on Raspberry Pi 4
Is there any documentation about configuring the GPIO's? My X86 system died, and I am trying to switch to my RPi4B (8GB).
I managed on the RPi to install LinuxCNC 2.8.2 on an SSD. However the documentation in that kit is not related to GPIO's it seems. Also the latest version of the LinuxCNC_documentation.pdf does not mention them.
I installed the utility rpi-gpio, but have no idea what the generated output means. Are there any GPIO configuration examples?
Thanks,
Robert
Thanks,
Robert
- elovalvo
18 Mar 2022 02:34 #237620
by elovalvo
in this link you can find an example of configuration:
forum.linuxcnc.org/9-installing-linuxcnc...-io-pins-only#203365
The following user(s) said Thank You: Elco
22 Mar 2022 18:24 #238049
LinuxCNC has a driver for the Pi GPIO, but it is barely documented (and as it only builds at all when the target is the Pi it doesn't show up in the lists)
There is an example HAL file, and that's your lot. Sadly.
github.com/LinuxCNC/linuxcnc/blob/master...hal_pi_gpio_demo.hal
