LinuxCNC on Raspberry Pi 4
4 years 5 months ago #243809 by malare
Replied by malare on topic LinuxCNC on Raspberry Pi 4
 I flashed LinuxCNC 2.8.1   Raspberry Pi OS based on Debian 10 Buster  on a card and tried it on a RPi400. When I first started it there were a message that the CPU is not supported but it started anyway and everything seemed to work (exept wi-fi) until I should shutdown the RPi400. I couldn't shut it down, it always restarted. What does this mean?
Many regards,  malare
4 years 5 months ago #243871 by elovalvo
Replied by elovalvo on topic LinuxCNC on Raspberry Pi 4
If you need to use version 2.8 (64-bit) you can take the image you find here.
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=120#224608
LinuxCNC also works on raspi400 (I have one and have checked) but the version is not the most recent and therefore the hal_pi_gpio driver does not work.
If you want to use version 2.9 instead you can use the image you can download here
forum.linuxcnc.org/9-installing-linuxcnc...cnc?start=130#238020
The following user(s) said Thank You: malare
4 years 4 months ago #245365 by andypugh
Replied by andypugh on topic LinuxCNC on Raspberry Pi 4
I am expecting to release a 2.8.3 fairly soon. Would you expect that to fix this? Or is there more to do?
4 years 4 months ago - 4 years 4 months ago #245382 by elovalvo
Yes, the new version will solve the problem.
My observation is due to the fact that the correction of the hal_pi_gpio file is dated 21 March while the SD image to which the link refers dates back to October 2021
One question: Will version 2.8.3 still be based on Debian Buster or will it use Bullseye?
Last edit: 4 years 4 months ago by elovalvo.
4 years 4 months ago #245528 by andypugh
It will be a re-spin of the current ISO, possibly with a couple of packaging fixes.
4 years 4 months ago - 4 years 4 months ago #246331 by Vector
Replied by Vector on topic LinuxCNC on Raspberry Pi 4
The third line of your comment... the link is now broken. I think you may have meant the buildbot page at buildbot.linuxcnc.org/ , but can you let us know if that's not what you meant? Thank you!
Dang it, I'm trying to respond to elovalvo's comments on Feb 28, but it keeps posting to the end of the thread. Sorry
Last edit: 4 years 4 months ago by Vector.
Time to create page: 0.134 seconds
