- Thank you received: 127
LinuxCNC on Raspberry Pi 4
- elovalvo
3 years 11 months ago - 3 years 11 months ago #255929
by elovalvo
But what operating system do you have?
In any case, install the xxd command with this
sudo apt install xxd
and then run the command again.
The following outputs should come out:
c03111
and
c03112
If so, I can edit the cpuinfo.c file easily.
Otherwise I will have to think of some other solution.
Replied by elovalvo on topic LinuxCNC on Raspberry Pi 4
Tried what you suggested with the following output
c03111
and
c03112
Last edit: 3 years 11 months ago by elovalvo.
- tjmarch
- Thank you received: 22
3 years 11 months ago - 3 years 11 months ago #255949
by tjmarch
Replied by tjmarch on topic LinuxCNC on Raspberry Pi 4
Last edit: 3 years 11 months ago by tjmarch.
- Thank you received: 4153
3 years 11 months ago #255990
Replied by rodw on topic LinuxCNC on Raspberry Pi 4
Ooops sorrry, the debian images do not include a graphical environment. This is pretty easy to install and you have a choice of environments.
sudo apt install tasksel
sudo tasksel
- elovalvo
3 years 11 months ago #256001
by elovalvo
Does this solve the cpuinfo problem?
Code:sudo apt install tasksel sudo tasksel
3 years 11 months ago #256007
I don't know about any cpuinfo problem. Its never been an issue for me...
Installing the graphical environment, I got from this tutorial..
I've been meaning to dig out a pi and try adding preempt_rt from my post earlier
forum.linuxcnc.org/9-installing-linuxcnc...pi-4?start=30#252319
Previously it was a bit involved to get it installed.
The one that I got a bit stuck on was vtk was not available in the repos. But it looks like vtk7 is now in Bookworm for arm64
packages.debian.org/search?suite=default...=names&keywords=vtk7
It was quite a lengthy process to build from source.
I'm not sure about which version of qt should be installed for qtpyvcp/qtvcp Is it now qt6?
- tjmarch
3 years 11 months ago #256231
by tjmarch
elovalvo
wrote "But what operating system do you have?
c03111
and
c03112
Otherwise I will have to think of some other solution."
Was just wondering if you were able to update cpuinfo.c
c03111
and
c03112
Time to create page: 0.896 seconds
