LinuxCNC on Raspberry Pi 4
4 years 1 day ago - 4 years 1 day ago #255543 by dannym
Replied by dannym on topic LinuxCNC on Raspberry Pi 4
I got the 2022.01.21 Bookworm to boot, but username "pi", password "raspberry" didn't work. "user"/"live" and "user"/"password" also no-go. Checked caps lock.
I'm seeing that raspi.debian.net/ says it ships with no username/password set. But it's demanding those. Just hitting "enter" twice does not work.  I can't get a command line and don't see any way to continue yet
EDIT: turns out it's username "root", no password
Last edit: 4 years 1 day ago by dannym.
3 years 11 months ago #255814 by tjmarch
Replied by tjmarch on topic LinuxCNC on Raspberry Pi 4
Saw this so thought I would give bookworm a try everything went well until I ran my config setup. When starting Linuxcnc I received the error screen. Attached is error log file. Which contains the following error. HAL_PI_GPIO: ERROR: board revision 7 not supported. I have a RPI4 4GB.
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/tim/linuxcnc/configs/rpi-grbl-mill'
Machine configuration file is 'rpi-grbl-mill.ini'
INIFILE=/home/tim/linuxcnc/configs/rpi-grbl-mill/rpi-grbl-mill.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./rpi-grbl-mill.hal
Found file(REL): ./custom.hal
Found file(REL): ./standard_pinout.hal
Debug file information:
Note: Using POSIX realtime
hal_pi_gpio: rtapi_app_main: Invalid argument (-22)
./standard_pinout.hal:8: waitpid failed /usr/bin/rtapi_app hal_pi_gpio
./standard_pinout.hal:8: /usr/bin/rtapi_app exited without becoming ready
./standard_pinout.hal:8: insmod for hal_pi_gpio failed, returned -1
1543
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file:    /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
     pastebin.com
in order to provide information about the linuxcnc
system and configuration.
                Date: Thu Nov 3 01:23:15 UTC 2022
            UTC Date: Thu Nov 3 01:23:15 UTC 2022
        this program: /usr/bin/linuxcnc_info
              uptime: 01:23:15 up 1 min, 1 user, load average: 1.97, 1.01, 0.39
     lsb_release -sa:
            linuxcnc: /usr/bin/linuxcnc
                 pwd: /home/tim/linuxcnc/configs/rpi-grbl-mill
                USER: tim
             LOGNAME: tim
                HOME: /home/tim
              EDITOR:
              VISUAL:
            LANGUAGE:
                TERM: dumb
           COLORTERM:
             DISPLAY: :0.0
             DESKTOP: lightdm-xsession
        display size: 1440x900 pixels (381x238 millimeters)
                PATH: /usr/bin:/home/tim/linuxcnc/configs/rpi-grbl-mill/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
         nodename -n: rpi4-20221010
      kernel-name -s: Linux
      kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.0.5-1 (2022-10-28)
          machine -m: aarch64
        processor -p: unknown
         platform -i: unknown
      oper system -o: GNU/Linux
/proc items:
             cmdline: video=HDMI-A-1:1440x900M@60 dma.dmachans=0x37f5 bcm2709.boardrev=0xc03111 bcm2709.serial=0x212d5d51 bcm2709.uart_clock=48000000 bcm2709.disk_led_gpio=42 bcm2709.disk_led_active_low=0 smsc95xx.macaddr=DC:A6:32:08:46:E0 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty0 console=ttyS1,115200 root=LABEL=RASPIROOT rw fsck.repair=yes net.ifnames=0 rootwait processor.max_cstate=1 isolcpus=2,3
          model name:
               cores:
             cpu MHz:
             parport:
              serial:
Versions:
/usr/bin/linuxcnc_info: line 154: gcc: command not found
                 gcc:
              python: Python 3.10.8
                 git: not_in_PATH
          git commit: NA
                 tcl: 8.6
                  tk: 8.6
               glade: not_in_PATH
linuxcnc_var all:
     LINUXCNCVERSION: 2.9.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
            REALTIME: /usr/lib/linuxcnc/realtime
                 RTS: uspace
          HALLIB_DIR: /usr/share/linuxcnc/hallib
              PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                Version                             Architecture Description
un  linuxcnc            <none>                              <none>       (no description available)
un  linuxcnc-dev        <none>                              <none>       (no description available)
un  linuxcnc-doc        <none>                              <none>       (no description available)
ii  linuxcnc-doc-en     2.9.0~pre0+git20220906.02744cdef6-1 all          motion controller for CNC machines and robots (English documentation)
un  linuxcnc-doc-es     <none>                              <none>       (no description available)
un  linuxcnc-doc-fr     <none>                              <none>       (no description available)
un  linuxcnc-sim        <none>                              <none>       (no description available)
un  linuxcnc-sim-dev    <none>                              <none>       (no description available)
ii  linuxcnc-uspace     2.9.0~pre0+git20220906.02744cdef6-1 arm64        motion controller for CNC machines and robots
ii  linuxcnc-uspace-dev 2.9.0~pre0+git20220906.02744cdef6-1 arm64        PC based motion controller for real-time Linux
3 years 11 months ago - 3 years 11 months ago #255823 by elovalvo
Replied by elovalvo on topic LinuxCNC on Raspberry Pi 4
The problem is due to the cpu_info.c file
github.com/LinuxCNC/linuxcnc/blob/master...al/drivers/cpuinfo.c
which refers to what is reported in this document:
www.raspberrypi.com/documentation/comput...ry-pi-revision-codes
To check what your Raspberry board revision is, see the result of the 'pinout' or 'cat /proc/cpuinfo' command executed in the terminal.
If the revision is present among those reported in the cpuinfo.c file, the version of linuxcnc used is not updated.
If it is not present, the file will need to be updated.
Let me know
Last edit: 3 years 11 months ago by elovalvo.
3 years 11 months ago #255846 by tjmarch
Checked, cat /proc/cpuinfo
with the following output. Thank you for the help elovalvo, what next, looks like revision 3 which is there.
tim@rpi4-20221010:~$ cat /proc/cpuinfo
processor : 0
BogoMIPS : 108.00
Features : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
3 years 11 months ago #255850 by elovalvo
You forgot to report the last 4 lines that report revision information like this
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : c03131
Serial : 1000000079326ffc
Model : Raspberry Pi 400 Rev 1.1
3 years 11 months ago - 3 years 11 months ago #255851 by tjmarch
That is all that there was to report i have included a screen shot.
Last edit: 3 years 11 months ago by tjmarch.
Time to create page: 1.439 seconds
