Installation Nightmare! All out of ideas! :-(
4 years 5 months ago #242748 by SimonCNC123
No offence taken Robert, I find that starting any engineering discussion with 'Explain it to me as if I know nothing' is often a very good place to start! :-).
Now that I have linux installed (on both devices) I should probably start a new thread in the Probe Basic section?
4 years 5 months ago #242749 by rodw
I did briefly try the Pi 4B with the 64 but bullseye version of Pi OS. I found a preempt_patch which installed ok, QT5 installed OK. But VTK did not run. I also could not install ethercat which I think was related to the RPi kernel not being in step with a normal Bullseye version 5.10.
So being unable to run QTPlasmac or Ethercat, I gave up as it was of no use to me.
But aside from all that, the latency was remarkably good, similar to a J1900 or I3. If you were just using gmocappy or axis, it is worth considering..
4 years 5 months ago #242759 by SimonCNC123
I'm a BIG fan of the little Pi's, we use them for all kinds of amazing stuff like multi million dollar data systems in mining where a Raspberry Pi is the ONLY interface between the production PLCs and the production reporting! :-). I also use one for switching guitar patches on the Fractal Axe processor in my band! :-)
BTW, I just posted some info on my build in the 'Show your stuff' section.
Thanks again for the help.
4 years 5 months ago #242762 by SimonCNC123
Sorry, one more thing, is there some secret to getting wifi working in this Debianedu12? When I open a terminal and it doesn't understand the command 'ifconfig' my heart sinks!
4 years 5 months ago #242763 by rodw
I think ifconfig needs to be installed: sudo apt install net-tools
technically its depreciated.
ip a gives a lot of info try it first.
4 years 5 months ago #242764 by SimonCNC123
Everything is so different in the distribution, I feel like I'm starting again! :-(
I don't see any wifi interface listed using ip -a. I know it has one as it was working when Windows was still installed!
Time to create page: 0.327 seconds
