- Thank you received: 7
LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
- CarterKraft
4 years 4 months ago #244968
by CarterKraft
Replied by CarterKraft on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Well 19.4 sure makes a difference from a following this guide point of view. Basically ZERO issues when starting from the correct OS version.
I am sure there are more hurdles to come but I have QtPlasmac up and running.
The following user(s) said Thank You: tommylight, snowgoer540
4 years 4 months ago #244988
by bevins
Replied by bevins on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Where is this install document?
- snowgoer540
- Topic Author
- Thank you received: 907
4 years 4 months ago #244992
by snowgoer540
Replied by snowgoer540 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
- CarterKraft
4 years 4 months ago #245995
by CarterKraft
After a successful install using this guide. What would be the next steps?
I am trying to get connected to my 7i96S but while I can ping it I don't seem to be able to find it with Mesaflash.
I am not sure where I am at in the process though, if it should work now or do I need to complete other steps.
I can make a new thread but I wanted to exhaust my options first.
- snowgoer540
- Topic Author
4 years 4 months ago #246007
by snowgoer540
Since it’s such a new card, and seems to be outside the scope of the install doc, I’d recommend a new post in the Driver Boards section. You’ll likely get more attention there and it will probably help someone else out as well.
The following user(s) said Thank You: CarterKraft
4 years 3 months ago #246706
by RDA
Replied by RDA on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Hello,
Any tips how can I force cpu governor to "performance" permanently? At the moment after reboot, the system reverts back to "powersave". As I dont know where this is loaded at boot, I would rather not just try a "random" file after googling.
Time to create page: 0.149 seconds
