- LinuxCNC
- Installing LinuxCNC
- LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
- Thank you received: 7487
06 Dec 2021 16:43 #228452
For that follow the easiest is to use the depreciated Wheezy ISO
linuxcnc.org/downloads/
Beware that it is not supported anymore.
Replied by tommylight on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
There should be RTAI kernel for 32bit, works for parallel and Mesa PCI and PCI-E cards, will not work for ethernet cards.
My client is a 32bit... is there an linux-image-rt-blabla32 ?
- Kiddekanin
- Thank you received: 3
06 Dec 2021 17:17 #228454
by Kiddekanin
Replied by Kiddekanin on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Thanks for the quick reply guys, much appreciated!
I, kidde, will hereby abandon all my old 32bit laptops for future Linuxcnc projects. From now on I will only use 64bit and the:
- LinuxCNC 2.8.2 Debian 10 Buster PREEMPT-RT ISO and eny future versions that may come .
- snowgoer540
- Thank you received: 907
06 Dec 2021 17:43 #228455
by snowgoer540
Replied by snowgoer540 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
In all honesty, if you are using a 64 bit PC, I highly recommend MX Linux from this guide, and not the LinuxCNC distributed ISO.
Laptops in general are not recommended for linuxcnc though...
- Kiddekanin
06 Dec 2021 18:28 #228456
by Kiddekanin
I will give it a go then.
Aiming for a 7i96 Plasma and a 7i96 gantry CNC
- Thank you received: 4149
07 Dec 2021 09:24 #228515
Replied by rodw on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
7i96 is nice for plasma but I personally would go with a 7i76e if you have a spindle.I will give it a go then.
- rfrey
08 Dec 2021 04:22 #228593
by rfrey
Replied by rfrey on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Thanks for this guide! I've run into a hitch, I wondered if anyone else had? When I clone mesaflash and run make, I get the error
"Makefile:61: ***"pkg-config can't find libcrypto". Stop."
I have libcrypto++6 and libcrypto++-dev installed.
Output from uname -a is
Linux novakon 4.19.0-18-rt-amd64 #1 SMP PREEMPT RT Debian 4.19.208-1 (2021-09-29) X86_64 GNU/Linux
Any pointers are greatly appreciated! I'm not sure where else this dependency might live. Openssl is also installed.
- snowgoer540
08 Dec 2021 16:28 - 12 Jun 2022 13:31 #228635
by snowgoer540
EDIT: the above is a result of changes to the Mesaflash install steps.
The install guide has been updated, but you can find the latest instructions here: github.com/LinuxCNC/mesaflash#readme
Follow the "Quickstart:" section.
Last edit: 12 Jun 2022 13:31 by snowgoer540.
- CarterKraft
10 Jun 2022 14:43 #244873
by CarterKraft
Replied by CarterKraft on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
I am giving this a shot to replace the Debian 11 install I was playing with previously. After going through the complete installation, removing the USB drive and clicking Finish the machine fails to reboot, I tried several times with the same result, it just loads the bios screen says no OS is on the drive.
This is on the newest version of the Source Forge link in the guide, MX 21.2? wildflower?
- snowgoer540
10 Jun 2022 17:05 - 12 Jun 2022 13:39 #244885
by snowgoer540
Last edit: 12 Jun 2022 13:39 by snowgoer540.
- CarterKraft
10 Jun 2022 19:47 #244899
by CarterKraft
Ok I will give it a shot tonight.
Thanks for the help.
- LinuxCNC
Time to create page: 0.279 seconds
