- LinuxCNC
- Installing LinuxCNC
- LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
- spumco
- Thank you received: 905
27 Sep 2021 01:12 #221676
by spumco
Replied by spumco on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
qtplasmac starts up with no errors.
qt install script has been re-run with no errors reported in the terminal session.
A few of the QT sims now work, but Woodpecker threw an error during shutdown.
I'll start a new topic in qtvcp, thank you for the guidance.
- bevins
- Thank you received: 338
28 Sep 2021 11:53 #221737
by bevins
Replied by bevins on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
OK this is nice. Installed no problem. I didnt see the rt kernel get installed.
and uname-a doesnt show it. Which rt kernel do I need to compile?
- snowgoer540
- Thank you received: 907
28 Sep 2021 11:59 #221738
by snowgoer540
Replied by snowgoer540 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
I think you just missed a step. It’s in the second pdf, section 4, step 19.
- bevins
28 Sep 2021 12:03 #221739
by bevins
You didnt say I had to read everything..... lol
- snowgoer540
28 Sep 2021 12:08 #221740
by snowgoer540
haha it's like making cookies, only the good news is when you forget to add the baking soda, you can fix it later, instead of finding out after you have inedible wafers with chips in them and it's too late
- bevins
28 Sep 2021 12:13 #221741
by bevins
WOW, Great job man. pretty fast and lite window manager also I find.
- bevins
28 Sep 2021 12:15 #221743
by bevins
I have a working plasma on linuxmint 19. I didnt update it cause I was afraid it would break. But I need top get it to the latest QTPlasmaC.
Should I install MX using this method and copy the config folder over? Would that work?
- snowgoer540
28 Sep 2021 12:22 - 28 Sep 2021 12:22 #221745
by snowgoer540
Thanks for the kind words, I am happy people seem to be getting good use out of the guide.
I would recommend using the backup button on the Parameters tab, but yes, it will work.
In the 3rd PDF, Section 9 walks you through how to restore a previously working QtPlasmaC config. The most cumbersome part is probably putting the folder in the right place, and then recreating the appropriate symbolic link.
Last edit: 28 Sep 2021 12:22 by snowgoer540.
- billykid
- Thank you received: 83
28 Sep 2021 17:17 #221767
by billykid
Replied by billykid on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
perfect .. i installed qtplasmac and the network works fine too without problems. only drawback for the same pc is the boot time almost double compared to buster but it is not a problem.
Thank you
Mauro
Thank you
Mauro
- Thank you received: 7478
02 Oct 2021 23:19 #222062
Replied by tommylight on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Just had a go at this on a Dell laptop, so from a 20 minute affair it is apparent that the Debian official install procedure works as is for 2.8.2:
linuxcnc.org/docs/2.8/html/getting-start...th_preempt_rt_kernel
Did not check 2.9 yet, need sleep badly, but pretty sure it will also work by changing the repos but i would not bet on it as it uses Python3.
Another thing i noticed, the part from section 4 > page 2 is a nice feature of MX and this makes me wonder, if MX has changing boot kernels why other distros do not???
Oh well..
Thank you Snowwy for a very detailed howto.
Regards,
Tom.
Oh well..
Regards,
Tom.
- LinuxCNC
Time to create page: 0.234 seconds
