- LinuxCNC
- Installing LinuxCNC
- LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
- phillc54
- Thank you received: 2100
26 Sep 2021 10:07 #221624
by phillc54
Replied by phillc54 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Yeah it was easy when it was python2.7 as that was the last 2 version so every distro had 2.7.
I could have sworn the Mint20 I built had python 3.8
- Clive S
- Thank you received: 486
26 Sep 2021 14:46 #221638
by Clive S
I decided to go with plan B and cloned the MXlinux drive and moved the config to it. Now its on the latest version
My next problem is the the bar at the bottom of the screen (task or panel) could do with auto hiding I haven't found the solution yet.
Replied by Clive S on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
It does. For deb and deb-src (which it looks like you may be missing, at least in the photo you provided) you need to edit the entry and change “stretch” to “buster”.
- snowgoer540
- Thank you received: 907
26 Sep 2021 15:13 #221641
by snowgoer540
Replied by snowgoer540 on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Right click on the panel (and hold it), slide to Panel and then Panel Preferences, release right click.
In the Display tab, under General, there is a drop down next to "Automatically hide the panel:". Never, Intelligently, Always
I am not sure what intelligently does, but either way, I think that is the option you are looking to change.
Glad to hear you got 'er goin!
- Clive S
26 Sep 2021 17:02 #221645
by Clive S
Thanks Snowy. That worked on the office machine with MX will try tomorrow on the MX plasma QT
Now I have 3 cloned drives and need to move a PlasmaC config over to QT I suppose I could manually just change all the pins in the hal and ini changes etc file over as I have QTplasmac on the drive.
The PlasmaC config is almost the same as mine just the Y axis is on different pins mesa 7i96
- snowgoer540
26 Sep 2021 17:05 #221647
by snowgoer540
Phill’s got you covered on this one:
linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_modify-config
- Clive S
26 Sep 2021 17:08 #221648
by Clive S
Yes I did see that. I have asked my friend 70 miles away to send me his config so that I can set it up for him on my plasma.
I will give it a try.
- snowgoer540
26 Sep 2021 17:14 #221649
by snowgoer540
No worries, both should work, so long as you catch all the important stuff.
If you are doing it for him, might be best to change the hal and ini files accordingly and send it back to him. Then you wont have to deal with messed up symlinks.
- spumco
- Thank you received: 905
27 Sep 2021 00:40 - 27 Sep 2021 00:41 #221670
by spumco
Replied by spumco on topic LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
Back to the drawing board...
LCNC is installed, and Axis/Gmoccapy sims work. But any Qtvcp screens throw error messages:
[attempted Woodpecker screen]
Traceback (most recent call last):File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 135, in qrccompilesubprocess.call(["pyrcc5", "-o", "{}".format(qrcpy), "{}".format(qrcname)])File "/usr/lib/python3.7/subprocess.py", line 323, in callwith Popen(*popenargs, **kwargs) as p:File "/usr/lib/python3.7/subprocess.py", line 775, in __init__restore_signals, start_new_session)File "/usr/lib/python3.7/subprocess.py", line 1522, in _execute_childraise child_exception_type(errno_num, err_msg, err_filename)FileNotFoundError: [Errno 2] No such file or directory: 'pyrcc5': 'pyrcc5' During handling of the above exception, another exception occurred: Traceback (most recent call last):File "/usr/share/qtvcp/screens/woodpecker/woodpecker_handler.py", line 104, in <lambda>STATUS.connect('interp-idle', lambda w: self.set_start_line(0))File "/usr/share/qtvcp/screens/woodpecker/woodpecker_handler.py", line 972, in set_start_lineself.w.lbl_start_line.setText('1')AttributeError: 'VCPWindow' object has no attribute 'lbl_start_line'
[different error attempting QTDragon HD]
Traceback (most recent call last):File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 135, in qrccompilesubprocess.call(["pyrcc5", "-o", "{}".format(qrcpy), "{}".format(qrcname)])File "/usr/lib/python3.7/subprocess.py", line 323, in callwith Popen(*popenargs, **kwargs) as p:File "/usr/lib/python3.7/subprocess.py", line 775, in __init__restore_signals, start_new_session)File "/usr/lib/python3.7/subprocess.py", line 1522, in _execute_childraise child_exception_type(errno_num, err_msg, err_filename)FileNotFoundError: [Errno 2] No such file or directory: 'pyrcc5': 'pyrcc5' During handling of the above exception, another exception occurred: Traceback (most recent call last):File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 94, in <lambda>STATUS.connect('override-limits-changed', lambda w, state, data: self._check_override_limits(state, data))File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 523, in _check_override_limitsself.w.chk_override_limits.setChecked(False)AttributeError: 'VCPWindow' object has no attribute 'chk_override_limits'
Anyone know what these mean and how to sort it out? Or should this be moved to a different sub-forum?
Thanks,
Ralph
Thanks,
Ralph
Last edit: 27 Sep 2021 00:41 by spumco.
- snowgoer540
27 Sep 2021 00:50 - 27 Sep 2021 00:51 #221671
by snowgoer540
I'm not very familiar with either of those GUIs...
Does the qtplasmac sample screen that the docs tell you to try work?
Last edit: 27 Sep 2021 00:51 by snowgoer540.
- phillc54
27 Sep 2021 01:03 #221674
by phillc54
If you have successfully run the Qt install script:
then it may be best to post on the QtVCP section.
forum.linuxcnc.org/qtvcp
- LinuxCNC
Time to create page: 0.492 seconds
