LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
After going through the complete installation, removing the USB drive and clicking Finish the machine fails to reboot, I tried several times with the same result, it just loads the bios screen says no OS is on the drive.
Enable CMS, disable UEFI, disable "secure boot", all in BIOS, try again. Might work without the need to reinstall.
Perhaps, but it will yield a Bullseye system, and not a Buster system. Which, to a new user makes everything much more complex.
How is changing BIOS settings going to change what Debian gets installed???
Not nice.
- snowgoer540
- Topic Author
- Thank you received: 907
It wont, I was referring to the fact that he said he installed the latest link on the sourceforge site (MX Linux 21.2), which would be based on Debian 11. So it kind of shoots the Subject Topic's install guide in the foot from the beginning is all I meant.
Wasn't my intent. I apologize if that is how it came acrossNot nice.
- CarterKraft
- Thank you received: 7
I get that (starting on 19.4) , which is the reason I brought it up. On both of my machines, windows and linux it downloads 21.2 no 19.4 even though the file says as much.
tommylight post=244907 userid=17274
Not nice.
For me this is drinking from the fire hose. I know enough to try, which is not fun at times.
This whole dialect/architecture is very tough to troubleshoot for rookies and I am giving it my all but there is LOTS of struggle. Even following this well thought out and put together guide I am at a less than 50% success rate for each command.
I blew off the Mesa Flash issue (I don't even have a Mesa card to use yet) and moved on to the linuxcnc part which fails again for various reasons.
Where I am currentyl...
GPG error: buildbot.linuxcnc.org buster InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY EF1B07FEE0EE663EThe repository ' buildbot.linuxcnc.org buster InRelease' is not signed.
- CarterKraft
drive.google.com/drive/folders/1LtMXI9l3...nfvPxaDO1Lfte5pCtuu_
Last one for the night.
Mesaflash fails here because "pkg-config can't find libmd"
root@mx:/home/ckcplasma# sudo apt install libpci-dev pkg-config build-essential git
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
build-essential is already the newest version (12.9).
git is already the newest version (1:2.30.2-1).
libpci-dev is already the newest version (1:3.7.0-5).
pkg-config is already the newest version (0.29.2-1).
The following packages were automatically installed and are no longer required:
libllvm11 libllvm11:i386 libqt5sensors5 libqt5webkit5
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
root@mx:/home/ckcplasma# git clone github.com/LinuxCNC/mesaflash.git
fatal: destination path 'mesaflash' already exists and is not an empty directory.
root@mx:/home/ckcplasma# cd mesaflash
root@mx:/home/ckcplasma/mesaflash# make
Makefile:61: *** "pkg-config can't find libmd". Stop.
root@mx:/home/ckcplasma/mesaflash# sudo make install
root@mx:/home/ckcplasma/mesaflash# mesaflash --help
mesaflash: command not found
- snowgoer540
- Topic Author
For the key issue, this is from my install guide (and I 2x checked it works over here):
For the mesa flash issue, looks like they changed a dependency and I missed it. I am considering just adding a link to their instructions so they stay current, but in the meantime you just need to install the libmd-dev package. So:
As for the ISO download, I'm not sure what to say there. It downloads the correct one over here. Maybe try going to this link: sourceforge.net/projects/mx-linux/files/Old/ Then click the MX-19.4 folder, then click MX-19.4_x64.iso (it's about 16 lines down).
- CarterKraft
I will attempt to download the 19.4 file specifically from your link.
It's all part of the process, these things seem to be so fluid creating a static guide is substantial chore. I do appreciate the work put into it and helping me learn the process.
