LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
4 years 11 months ago - 4 years 11 months ago #227676 by snowgoer540
Thank you for the heads up that the link changed, I was unaware.  I will fix that.
I have it on my "to-do" list to make a MX21 install guide.  I have been holding off because there are no package installs being built automatically for this yet.  So currently for this to work, you have to install the correct dependencies and you have to build from source (Run In Place Install).  All that said, I figure most people who are new to LinuxCNC won't want to go that route as you dont get the menu items, etc.  It's more geared toward development work.
Perhaps I could just make the guide with that disclaimer...
EDIT:  The first guide has had the links updated.  Thanks again.
Last edit: 4 years 11 months ago by snowgoer540.
The following user(s) said Thank You: caretech
4 years 11 months ago #227686 by caretech
Looks like MX Linux 21 was just released about a month ago.
I also noted after posting previously that MX 21 is based on Bullseye. So I installed 19.4 instead and things are going much better now.
I can wait; if this works well, I'm happy. I'm still taking first steps with LCNC and not sure I want to try the build from source option just yet. Probably at some point in the future.
Regarding the MX experience overall -- Xfce 4.16 is sooooo much nicer than the outdated version that ships with the official ISO.
4 years 11 months ago #227718 by snowgoer540
I figure 19.4 is the safest bet at the moment. Good luck, let us know if you need anything.
4 years 11 months ago #227723 by rodw
you would need to compile from source to use MX21. I did that with bullseye without any dramas
4 years 10 months ago #228447 by Kiddekanin
Following the manual. word by word - line by line.
Section 4: 19:
enter the following case sensitive command:
sudo apt install linux-image-rt-amd64
My client is a 32bit... is there an linux-image-rt-blabla32 ?
or is the guide only for 64bit machines (I know it mentioned 64in the start - but i would give it a shot enyway)
4 years 10 months ago #228449 by snowgoer540
Yep, the guide is written with 64 bit machines in mind.
