- Thank you received: 59
Does LinuxCNC start?
I am still getting the "linuxcnc-uspace" with the red question mark ie broken package.
I will have to try aging tomorrow. Thanks
Sorry Clive, there is an issue with the package build, it confuses the filename and directory name. I will push a fix today. In the meantime you should be able to run it with the following command:
$ /usr/lib/python3/dist-packages/qtvcp/designer/install_script
bash: /usr/lib/python3/dist-packages/qtvcp/designer/install_script: Not a directory
If you did do a package install then you don't need to run the script unless you want Designer so that you can edit/make GUI files.
Code:/usr/lib/python3/dist-packages/qtvcp/designer If you did do a package install then you don't need to run the script unless you want Designer so that you can edit/make GUI files.
