LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
5 years 1 month ago #221641 by snowgoer540
Right click on the panel (and hold it), slide to Panel and then Panel Preferences, release right click.
In the Display tab, under General, there is a drop down next to "Automatically hide the panel:".  Never, Intelligently, Always
I am not sure what intelligently does, but either way, I think that is the option you are looking to change.
Glad to hear you got 'er goin!
5 years 1 month ago #221645 by Clive S
Thanks Snowy.  That worked on the office machine  with MX will try tomorrow on the MX plasma  QT
Now I have 3 cloned drives and need to move a PlasmaC config over to QT I suppose I could manually just change all the pins in the hal and ini changes etc file over as I have QTplasmac on the drive.
The PlasmaC config is almost the same as mine just the Y axis is on different pins mesa 7i96
5 years 1 month ago #221648 by Clive S
Phill’s got you covered on this one:
linuxcnc.org/docs/devel/html/plasma/qtpl...tml#qt_modify-config
Yes I did see that. I have asked my friend 70 miles away to send me his config so that I can set it up for him on my plasma.
I will give it a try.
5 years 1 month ago #221649 by snowgoer540
No worries, both should work, so long as you catch all the important stuff.
If you are doing it for him, might be best to change the hal and ini files accordingly and send it back to him.  Then you wont have to deal with messed up symlinks.
5 years 1 month ago - 5 years 1 month ago #221670 by spumco
Back to the drawing board...
LCNC is installed, and Axis/Gmoccapy sims work.  But any Qtvcp screens throw error messages:
[attempted Woodpecker screen]
Traceback (most recent call last):File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 135, in qrccompilesubprocess.call(["pyrcc5", "-o", "{}".format(qrcpy), "{}".format(qrcname)])File "/usr/lib/python3.7/subprocess.py", line 323, in callwith Popen(*popenargs, **kwargs) as p:File "/usr/lib/python3.7/subprocess.py", line 775, in __init__restore_signals, start_new_session)File "/usr/lib/python3.7/subprocess.py", line 1522, in _execute_childraise child_exception_type(errno_num, err_msg, err_filename)FileNotFoundError: [Errno 2] No such file or directory: 'pyrcc5': 'pyrcc5' During handling of the above exception, another exception occurred: Traceback (most recent call last):File "/usr/share/qtvcp/screens/woodpecker/woodpecker_handler.py", line 104, in <lambda>STATUS.connect('interp-idle', lambda w: self.set_start_line(0))File "/usr/share/qtvcp/screens/woodpecker/woodpecker_handler.py", line 972, in set_start_lineself.w.lbl_start_line.setText('1')AttributeError: 'VCPWindow' object has no attribute 'lbl_start_line'
[different error attempting QTDragon HD]
Traceback (most recent call last):File "/usr/lib/python3/dist-packages/qtvcp/qt_makegui.py", line 135, in qrccompilesubprocess.call(["pyrcc5", "-o", "{}".format(qrcpy), "{}".format(qrcname)])File "/usr/lib/python3.7/subprocess.py", line 323, in callwith Popen(*popenargs, **kwargs) as p:File "/usr/lib/python3.7/subprocess.py", line 775, in __init__restore_signals, start_new_session)File "/usr/lib/python3.7/subprocess.py", line 1522, in _execute_childraise child_exception_type(errno_num, err_msg, err_filename)FileNotFoundError: [Errno 2] No such file or directory: 'pyrcc5': 'pyrcc5' During handling of the above exception, another exception occurred: Traceback (most recent call last):File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 94, in <lambda>STATUS.connect('override-limits-changed', lambda w, state, data: self._check_override_limits(state, data))File "/usr/share/qtvcp/screens/qtdragon_hd/qtdragon_hd_handler.py", line 523, in _check_override_limitsself.w.chk_override_limits.setChecked(False)AttributeError: 'VCPWindow' object has no attribute 'chk_override_limits'
Anyone know what these mean and how to sort it out?  Or should this be moved to a different sub-forum?
Thanks,
Ralph
Last edit: 5 years 1 month ago by spumco.
Time to create page: 0.370 seconds
