LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
5 years 1 month ago - 5 years 1 month ago #221411 by billykid
no not pnconf .. run linuxcnc in a working configuration on buster. i tried to manually put the files in / usr / lib / firmware the hostmot files but it doesn't work.
Could not locate firmware "//lib/firmware/hm2/5i23/SVST4_8.BIT". (No such file or directory)
Last edit: 5 years 1 month ago by billykid.
5 years 1 month ago #221414 by phillc54
I have no clue on boards requiring firmware, it may be worthwhile posting in this section:
forum.linuxcnc.org/27-driver-boards
5 years 1 month ago #221417 by snowgoer540
Another option is reaching out to Peter at Mesa via the contact info on their page.  He's always responded and been helpful when I've needed it in the past.  But do post your findings here if you get it sorted out that way.
5 years 1 month ago #221422 by billykid
Certainly if I resolve in any way I will post it here
5 years 1 month ago #221423 by tommylight
Not the same as
one / to many.
5 years 1 month ago #221425 by billykid
Trust me Tom :-) the path was right, double slash was just in the message. the hm2 folder in usr / lib / firmware did not exist. i copied hm2 from buster 2.9 master disk on usb stick and with root file manager on mx 19 put it in the right place it works regularly. sorry I didn't think about it before but this problem never occurred. the 5i23 will be old but runs servo threads at 8 khz :-)
Time to create page: 0.172 seconds
