LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
5 years 1 month ago #221426 by snowgoer540
Glad you got it going!
I am curious, what exactly is in the hm2 folder?  And if it's another folder, then what's in that folder, and so on?
Just trying to capture what exactly needs to go in there for the future.
5 years 1 month ago - 5 years 1 month ago #221427 by billykid
the missing folder is in: / usr / lib / firmware it is called hm2 and contains the subfolders with the various mesa tabs. I am attaching mine that I copied.
I deleted some boards for the 1.6 mega limits of the forum but the structure is that.
Last edit: 5 years 1 month ago by billykid.
The following user(s) said Thank You: tommylight, snowgoer540
5 years 1 month ago #221431 by tommylight
Never used a 5i23, but i was sure no installation is required, just copy/paste the .bin files, recalled from when i was doing due diligence first time i ordered Mesa stuff.
Glad you figured it out, and yes the Mesa boards are magnificent pieces of enginiering!
Snowwy, older Mesa boards required having the bin file on the hdd at boot time they would load that as requested by loadrt in hal, new ones have that in EEPROM.
5 years 1 month ago #221432 by snowgoer540
I was not previously aware, so I'm glad to learn this, always love learning new things about this project.
I'm not sure if it should be included in my install docs or not, as I am not sure how common some of that older stuff is. But, I am open to suggestion. The discussion is also captured here, so that will likely help those in the future who have similar issues.
5 years 1 month ago #221434 by tommylight
Might wana check if they are still sold by Mesa, they are quite the beasts as Billy mentioned they can easily do 8KHz servo period, although i have pushed Mesa 5i25 or 6i25 ( not sure) to 4KHz.
And they have lots of pins, lots ! :)
The following user(s) said Thank You: billykid, snowgoer540
5 years 1 month ago - 5 years 1 month ago #221441 by Clive S
@Greg
First thanks for taking the time for the MX Linux 19.4 docs etc.
I would like to try this. Some time ago I set up a 1200x1200 size plasma with PlasmaC using the axis gui this is about 70 miles from home. It is a production machine so don't want it off line. This has run fine but as you know PlasmaC is EOL so want to convert it to QT.
The plan is to make another ssd with MX and set it up at home first on my machine then take it over and swap out the ssd's.
The setup up is very similar to mine both using a Mesa 7i96
Would MX be stable enough for what I want to do?
Edit: will it work on 32 and 64 bit ?
Last edit: 5 years 1 month ago by Clive S.
Time to create page: 0.430 seconds
