LinuxCNC Install using MX Linux 19.4 - Geared Toward New Users - Discussion
4 years 11 months ago #225911 by snowgoer540
A big thankyou to Señor Snowy as well.
You are quite welcome. Happy I could help!
4 years 11 months ago #227138 by RNJFAB
Snowgoer540
Any chance you could do an idiots guide to upgrading as well?
And as i write this i realise if i read through the files you have already made i'll find my answers !!
4 years 11 months ago #227144 by rodw
Snowgoer540
There isn't really much to moving from plasmac to qtplasmac  linuxcnc.org/docs/devel/html/plasma/qtpl...c.html#_quick_method
The following user(s) said Thank You: RNJFAB
4 years 11 months ago #227146 by RNJFAB
Thanks Rod,
It was the upgrading to the latest version of QtPlasmaC.
Step 5 i think of Snowgoer54's id10t's guide.
4 years 11 months ago #227190 by snowgoer540
Thanks Rod,
Yep, for a package install, Section 4, Steps 17 and 18 should get you up to date, which I see from the post in the other section that you've already figured out :)
Let me know if there's anything else I can help with.
4 years 11 months ago - 4 years 11 months ago #227663 by caretech
I followed the guide... almost. Turns out that 19.4 is now an older version -- I missed the memo, or else didn't figure the version difference should matter since this guide was so recently published -- and downloaded the current MX version 21. RT kernel install and Mesaflash build / install went perfectly fine. However, the linuxcnc install fails as follows.
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies:  linuxcnc-uspace : Depends: python3 (< 3.8) but 3.9.2-3 is to be installed                    Depends: libboost-python1.67.0 but it is not installable                    Depends: libpython3.7 (>= 3.7.0) but it is not installable                    Depends: libreadline5 (>= 5.2) but it is not installable E: Unable to correct problems, you have held broken packages.
So, do I need to start over with 19.4 because of python version incompatibility? Wouldn't mind staying with 21 if I could...
If it must be 19.4, you might consider updating the guide so that it uses  sourceforge.net/projects/mx-linux/files/...9.4_x64.iso/download for the download link. The link in the guide takes you to current release which is now 21.
MX 21 ships with Python 3.9.2.
Last edit: 4 years 11 months ago by caretech. Reason: formatting
Time to create page: 0.406 seconds
