Installing LinuxCNC 2.9 or Master on Linux Mint 21
4 years 3 months ago #247450 by JackRay
Hello, impossible to develop the "vismash" branch in the menu. But it's not a big deal, I just copied my configuration in the ./linuxcnc/config menu, made some adjustments to the access paths and EVERYTHING WORKS WONDERFULLY. My 5 axis TCP milling machine is operational.
Moreover this last version on linux mint is very easy to install
Thanks again to all this great team who helped me with a lot of patience (I hope you didn't take too many antidepressants) with me image missing /media/kunena/emoticons/smile.pngimage missing /media/kunena/emoticons/smile.pngimage missing /media/kunena/emoticons/smile.png.
Thank you very much for your help.
The following user(s) said Thank You: tommylight, Clive S
4 years 3 months ago #247655 by JT
Interesting when went to download the deb from
ftp.de.debian.org/debian/pool/main/l/lin...00863908-4_amd64.deb
I got a potential security risk warning.
But when I used this link without .de no problem was reported...
ftp.debian.org/debian/pool/main/l/linuxc...00863908-4_amd64.deb
JT
4 years 3 months ago - 4 years 3 months ago #247656 by JT
The menu is sure screwed up in Linuxmate 21 after a few minutes I managed to lose everything but the latency test lol...
Edit: Uninstalled LinuxCNC then installed again and now no menu items show up anywhere! I guess I'll start over...
JT
Last edit: 4 years 3 months ago by JT.
4 years 3 months ago #247657 by tommylight
Right click on the LM logo/start button, reload plugins .
Usually that fixes the menu.
4 years 3 months ago - 4 years 3 months ago #247667 by Samuelx
Thank you for this easy installation guide. Beginer like me got it up and running.
Last edit: 4 years 3 months ago by Samuelx. Reason: more info
4 years 3 months ago #247669 by scotth
I spent Sunday installing Mint 21 on the system. Using Tommylight's instructions, everything went fine. It worked so well, I tried it with MX21, and it worked also.
Latency looks ok, no problems with Sim.
Having the extra drivers for Linux helps a lot.
Time to create page: 0.224 seconds
