Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
2 years 9 months ago #290026 by tommylight
Probably should have been written as x86_64, but i never got a reply from Rod if it works as 64 bit or not.
Also there are several X86 versions, before PAE and after, but those are always 32 bit.
This is not our fault,it is absolutely Intel's fault on every level.
That is why all the 64 bit versions of Linux kernels have AMD64 in their name, despite working on Intel stuff flawlessly.
2 years 9 months ago #290029 by rodw
its 64 bits only. I did not know 32 bit pcs still existed... Some IT guys just want to be pedantic :)
2 years 9 months ago #290078 by Stefan85
tommylight, Thanks for the explanations.
rodw, I'll just replace my old computer.
2 years 9 months ago - 2 years 9 months ago #290282 by avakato
First I would just like to say thank you for all your work on this and am glad you are getting better.
I would just like to report that I just did a fresh install of LinuxCNC 2.9.2 from ( www.linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso ) and still experience the raspi-firmware script trying to run during an upgrade of the kernel.
/etc/kernel/postinst.d/dkms: dkms: running auto installation service for kernel 6.1.0-17-rt-amd64. dkms: autoinstall for kernel: 6.1.0-17-rt-amd64. /etc/kernel/postinst.d/initramfs-tools: update-initramfs: Generating /boot/initrd.img-6.1.0-17-rt-amd64 raspi-firmware: missing /boot/firmware, did you forget to mount it? run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1 ... Errors were encountered while processing: # linux-image-6.1.0-17-rt-amd64 # linux-image-rt-amd64
The previous solution of removing it along with purging it from it from the system works and allows the upgrade to complete.
# rm /etc/{initramfs/post-update.d/,kernel/{postinst.d/,postrm.d/}}z50-raspi-firmware # apt purge raspi-firmware
I am not sure if the scripts being in the ISO effect it? e.g.
LinuxCNC_2.9.2-amd64.hybrid.iso\live\filesystem.squashfs\etc\kernel\postinst.d\z50-raspi-firmware LinuxCNC_2.9.2-amd64.hybrid.iso\live\filesystem.squashfs\etc\initramfs\post-update.d\z50-raspi-firmware
Thank you again!
Last edit: 2 years 9 months ago by avakato.
The following user(s) said Thank You: hilo90mhz
2 years 9 months ago #290293 by rodw
This is very frustrating. It needs to be reported as a bug to Debian.
2 years 9 months ago #290983 by hilo90mhz
I think your line:
Installation of Ethercat - sudo apt install ethercat-master libethercat-dev
should also have:
linuxcnc-ethercat
at the end? that was missing for me.
Thanks for this image! made it wayyy easier than last time
Time to create page: 0.565 seconds
