Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
2 years 11 months ago - 2 years 11 months ago #286520 by tommylight
That raspberry pi bug seems to have returned to Debian core code. Its not a Linuxcnc thing
It never left, Rod, not in this ISO you provided. I am aware you mentioned several times you fixed it, apparently it is still there.
12.1 and 12.2 BookWorm do not have this issue, 12.0 did since it's pre-release.
Did not have time to check the official ISO version yet although i had downloaded it before it was released to public, bumped into it by accident! :)
Edit:
Question, when you do a new ISO build, did you delete absolutely everything before starting?
The working folder must be clean, otherwise... this happens.
Last edit: 2 years 11 months ago by tommylight. Reason: more info
2 years 11 months ago #286525 by rodw
Just to be clear Tommy, this pi firmware is not installed by Linuxcnc. The issue is with Debian because we use the official Debian Live Installer.
We don't even to any shell scripting, we just configure it all through files and settings.
I did occasionally see the name pop up when the installer runs.
I think that it is possible to tell the installer not to install a package. maybe we can do that.
2 years 11 months ago #286549 by tommylight
Yes it is a Debian issue, not a LinuxCNC issue.
Who implied otherwise?
2 years 10 months ago #288609 by lunada
keep getting this error:
ncrouter@cncrouter:~$ sudo apt purge raspi-firmware
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages will be REMOVED:
  raspi-firmware*
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up initramfs-tools (0.142) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-6.1.0-15-rt-amd64 (6.1.66-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-15-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-15-rt-amd64.
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-15-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-6.1.0-15-rt-amd64 (--configure):
 installed linux-image-6.1.0-15-rt-amd64 package post-installation script subprocess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-rt-amd64:
 linux-image-rt-amd64 depends on linux-image-6.1.0-15-rt-amd64 (= 6.1.66-1); however:
  Package linux-image-6.1.0-15-rt-amd64 is not configured yet.
dpkg: error processing package linux-image-rt-amd64 (--configure):
 dependency problems - leaving unconfigured
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
2 years 10 months ago #288612 by rodw
I don't understand why this is happening. Is it a new installation?
Why has dkms been loaded? do you have any drivers (eg realtek NIC drivers) installed that requires it?
2 years 10 months ago - 2 years 10 months ago #288616 by tommylight
Still the old image with raspi issues????
forum.linuxcnc.org/39-pncconf/50179-a-li...zard?start=30#281934
Last edit: 2 years 10 months ago by tommylight. Reason: added link
