Debian 12 - Bookworm Live installer ISO for linuxcnc (x86_64)
3 years 2 weeks ago #282905 by CNCGOOS
Hello all, i have worked toda for the first time with 2.9works well. only just i want to start te systrem again, i have gote an error there is somthing wrong with a Tool Parameter. i dont know of is du to 2.9 or somthing else.
i hpe this is the write tread for this question.
her e part of the report file
  File "/usr/bin/gmoccapy", line 5768, in <module>
    app = gmoccapy(sys.argv)
  File "/usr/bin/gmoccapy", line 276, in __init__
    self._get_pref_data()
  File "/usr/bin/gmoccapy", line 576, in _get_pref_data
    self.prefs = preferences.preferences(self.get_ini_info.get_preference_file_path())
  File "/usr/lib/python3/dist-packages/gmoccapy/preferences.py", line 32, in __init__
    self.read(self.fn)
  File "/usr/lib/python3.11/configparser.py", line 713, in read
    self._read(fp, filename)
  File "/usr/lib/python3.11/configparser.py", line 1112, in _read
    raise DuplicateOptionError(sectname, optname,
configparser.DuplicateOptionError: While reading from '/home/joost/linuxcnc/configs/CNCGoos/CNCGoos.pref' [line 76]: option 'system_name_tool' in section 'DEFAULT' already exists
 (gmoccapy:62)
3 years 2 weeks ago #282942 by rodw
This seems to be a Gmoccappy fault and nothing to do with the installer.
Please raise a new thread in their section of the forum so they see it.
The following user(s) said Thank You: CNCGOOS
3 years 2 weeks ago - 3 years 2 weeks ago #283052 by Franklin
Last edit: 3 years 2 weeks ago by Franklin.
3 years 1 week ago #283298 by probotix
I am trying to run my own live-build on a bookworm install, but get this error:
Errors were encountered while processing:
 linux-image-6.1.0-13-rt-amd64
 linux-image-rt-amd64
Any ideas?
3 years 1 week ago #283311 by robh
is this the error of something like this ...
in case someone else has the below error on a update/upgrade
update would always get stuck trying to installl the updated linux-image packages
debian 12 raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
i had this, seems a very common bug unfixed still in debian
if you google this you will find many reff to this and help topics
i found running
sudo dpkg --purge raspi-firmware
sudo apt autoremove --purge raspi-firmware
sudo apt-get upgrade
fixed the error..
Time to create page: 0.325 seconds
