Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
- Thank you received: 423
15 Nov 2023 12:01 #285490
Replied by Cant do this anymore bye all on topic Debian 12 - 2.10 master branch image for the Raspberry Pi 4b/400
Hahaha I knew a while back you were in favour of office.
forum.linuxcnc.org/18-computer/34823-a-f...d-up?start=20#113495
Just a friendly dig old mate.
- McFly
- Visitor
17 Nov 2023 01:02 - 17 Nov 2023 01:12 #285676
by McFly
Replied by McFly on topic Debian 12 - 2.9.1 image for the Raspberry Pi 4b/400
Hi!
Just some regular CNCer, already proficient with my rpi4 8gb and 2.8. I thought I might try something else, test some stuff. Been reading around here for some days now. I tried to run that image (the one from Rod's first post):
rpi-4-debian-bookworm-6.1.54-rt15-arm64-ext4-2023-10-21-1847.img
but it gave me that screen (see attached file). Seems to be hardware related...
Last edit: 17 Nov 2023 01:12 by McFly.
- Thank you received: 3784
17 Nov 2023 02:00 #285677
Replied by rodw on topic Debian 12 - 2.9.1 image for the Raspberry Pi 4b/400
Yes, I get that error too on my older Pi 4b
Lots of others have it working for them.. Just hardware I think
- McFly
- Visitor
17 Nov 2023 14:37 #285741
by McFly
Any work around? Switching to a x86 computer?
17 Nov 2023 20:43 #285777
Yes, use X86. I have never used the Pi for linuxcnc. I did spend days trying in the past which is why I built ths installer so there was an easy way and none of the Linuxcnc devs had a working image.
17 Nov 2023 20:55 #285779
Replied by Cant do this anymore bye all on topic Debian 12 - 2.9.1 image for the Raspberry Pi 4b/400
I've seen that message on my RP-400 but it still boots and runs fine.
I'm going to go out on a limb and judging by "seat of the pants" the RPi-5 is just about on par with a low-end x86 system that is capable of running Linuxcnc.
- eman5oh
- Thank you received: 11
24 Nov 2023 20:43 - 24 Nov 2023 20:44 #286427
by eman5oh
Replied by eman5oh on topic Debian 12 - 2.9.1 image for the Raspberry Pi 4b/400
Is this a different image than the one on the downloads ,link below? I am unable to get one linked below to work with my mesa 7i76e, I keep getting following errors even with the servo thread set to 2ms. I had the same config working under 2.8 on the same pi 4b. I remember having to set the system to stay on one core to get it working, is that still needed?
-Thanks
www.linuxcnc.org/iso/linuxcnc-2.9.1-bookworm-rpi4.img.xz
-Thanks
Last edit: 24 Nov 2023 20:44 by eman5oh.
24 Nov 2023 22:21 #286433
The image I built was copied to linuxcnc repos so no.
The later one of mine has some changes around repositories and also added network manager because guys were complaining bout not being able to easilly set the wifi settings (which can be set in menu-config anyway)
2.8 used a 32 bit kernel, this is 64 bit
All of the isolcpus settings are already done for you.
Lots of guys are using this with 1 ms servo period without following errors.
Following errors are related to your tuning, error finishing read is a hardware issue which is a kernel problem affecting mesa cards but we have not seen reports of that on the pi.
- eman5oh
25 Nov 2023 02:33 #286436
by eman5oh
Thanks for the info and the time you put in making the PI image. I must just have a bum pi4, I get the sculls error at boot but it boots up and runs. I downloaded the image you have linked to this thread and loaded my config after setting the network interface to 10.10.10.1 and leaving wifi off, I ran it for a bit and I got realtime servo thread errors and then the joint following errors, same config runs on my I5 Intel NUC. I wonder if my pi is is overheating or has some other hardware issue. I need to find another pi4 and try again. Thanks!
25 Nov 2023 06:03 #286440
Checked that the governor is set to performance.
But yeah if it is overheating it will throttle down. A heatsink\fan might help.
But if the NUC is ok I'd stick with that.
Time to create page: 0.087 seconds
