LinuxCNC on Raspberry Pi 5
1 year 8 months ago #320958 by KrisJ
Replied by KrisJ on topic LinuxCNC on Raspberry Pi 5
(Sorry for double posting. Cant edit last post, can only see the block quote when i try to edit)
I found a solution for my missing WiFi connections.
Second method mentioned in the top reply. (first method didn't work for me)
askubuntu.com/questions/71159/network-ma...s-device-not-managed
Then open the file:
sudo nano /etc/network/interfaces
Delete everything in that file and copy and paste the following:
auto lo
iface lo inet loopback
Save, stop and start network manager:
sudo service network-manager restart
I had to reboot my whole system but after that WiFi works like expected.
1 year 8 months ago #321039 by jhandel
Replied by jhandel on topic LinuxCNC on Raspberry Pi 5
So with the official image if I install Network Manager then it fails at between 50k and 70k pings... However if I leave the network bone stock like the image (so using commandline and config files to manage) then 100000 pings at 1ms/ping and a response time of 0.105ms so yah... I think it was Network Manager that was the problem.
1 year 8 months ago #321042 by unknown
Replied by unknown on topic LinuxCNC on Raspberry Pi 5
What is the actual command are you using for ping
1 year 8 months ago #321052 by jairobbo
Replied by jairobbo on topic LinuxCNC on Raspberry Pi 5
After using two model of pi (4B and 5) I still get disappointing results. Even at slow printing speeds around 25mm/s there is layer shifting and unreliable motion throughout the operation. I believe now that pi + GPIO struggles to keep up with the pulse generation. Even though I am doing indexed printing (orienting the bed only between sections of printing, so no full 5 axis kinematics) My application is a 5 axis (3 + 2 tilting bed) 3d printer.
I think this was mentioned in the instructions that the PREEMT linux kernel was compatible only, but not recommended as 'industry standard'. Since I cant afford a Mesa FPGA card I am going for klipper on an Octopus board and try my best there. Thanks everyone for being super helpful. And if anyone is interested my 5 axis slicer is on Github, it is A Blender addon that works if you also have the Cura engine up and running. You would be able to slice more complicated models with overhang and printing it by rotating the bed (if you do have this kind of setup).
github.com/bbo-git/5AxisSlicerBlenderAddon
Cheers!
Jairo
1 year 8 months ago #321053 by unknown
""I think this was mentioned in the instructions that the PREEMT linux kernel was compatible only, but not recommended as 'industry standard'.""
What do you mean by this ?
I guess you haven't seen this:
github.com/ozzyrob/Linuxcnc-FPGA
1 year 8 months ago #321054 by jairobbo
I mean by that you need additional hardware to get good results. The Pi alone even the 5 cannot handle it is my finding and conclusion.
Time to create page: 0.452 seconds
