- Thank you received: 426
If it's Rod's image can you change the resolution and does it identify the display\monitor? From what I've seen it's stuck at a single resolution and it can't identify the dsiaplay as the RPi4 images can.
Yes, my image uses debian so it won't have the pi specific menu options.. Some settings can be changed using sudo menuconfig.
But if you could try adding
video=HDMI-A-1:1920x1080M@60D
to cmdline.txt or equivalent, It would be helpful. If it works, I can add it to the installer.
Its still a pain because the Pi 5 needs to be at the bleeding edge of the raspberry kernel and the PREEMPT_RT is lagging behind that.
