- Thank you received: 426
Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
2 years 11 months ago #285702
Replied by Cant do this anymore bye all on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Debian has some info here.
wiki.debian.org/Wayland#Xwayland
Or if you start with raspios lite (no desktop) and install xfce as the desktop enviroment.
or.. as per help.realvnc.com/hc/en-us/articles/14110...-and-RealVNC-Connect
Raspberry Pi 4-5: This device defaults to using Wayland (wayfire) on Pi OS Bookworm, however it is possible to switch to X11 by using the command line raspi-config utility, under Advanced Options -> Wayland. Our initial testing indicates that RealVNC Connect functions as expected in this mode.
The following user(s) said Thank You: pietvr
- Thank you received: 4153
2 years 11 months ago #285703
Replied by rodw on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
The method is buried in comments in a commit or issue in linuxcnc's git
I'll wait patiently for my image to be tested. .....
- pietvr
- Thank you received: 21
2 years 11 months ago #285705
by pietvr
Replied by pietvr on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Thanks Rod, you pointed me in the right direction and there was an easy fix
here
. Sorry I don't have Pi 5 yet to test your image.
- Calysto
- Thank you received: 6
2 years 11 months ago #285744
by Calysto
Replied by Calysto on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
New here.... my Pi4 1GB (yes, it exists!
) isn't good enough, my Pi5 4GB will be here soon. I'll test your images!
- elovalvo
- Thank you received: 127
2 years 11 months ago #285748
by elovalvo
Those interested in having a working image on Raspberry Pi 5 can refer to this post:
forum.linuxcnc.org/9-installing-linuxcnc...berry-pi-5?start=20# 285747
Replied by elovalvo on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
The following user(s) said Thank You: Calysto
2 years 11 months ago #285752
ATM I can't quite get SPI working, I think I may have a solution but will need to do some testing.
Just wondering if anyone else has found this to be an issue ?
This may affect 7i90, 7c80 and 7c81 boards.
Mesaflash seems to have an issue as well.
So far I've had no input from anyone on this issue.
