Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
2 years 11 months ago #286690 by elovalvo
I think many posts in this thread are completely unrelated to the topic I started it with.
My idea was to compare the performance of the Raspbian Bookworm (and not the Debian) on Pi4 and Pi5....
2 years 11 months ago #286691 by rodw
ITs difficult for users to compare the products until they have a robust installation method for the pi5. But it has been reported latency is much improved.
2 years 7 months ago - 2 years 7 months ago #295266 by pgf
The results are definitely surprising     [code][code]Regarding this...  is it understood why the latency was so much better in the RPi 5 test, than the RPi 4?  Is this purely a result of improved processor performance, or is there some other underlying reason?  (And, has that result been reproduced?) Unless I'm misunderstanding, I think that latency is quite a bit better than I currently get on my 10 y.o. AMD PC, which implies I could potentially replace it (and its parallel port) directly with an RPi 5 and its gpio pins.  Which I confess excites me a bit.  :-) paul
[/code][/code]
Last edit: 2 years 7 months ago by pgf. Reason: text was incorrectly... tried again. and again.... argh. it's getting worse. I give up.
  • Platinum Member
  • Platinum Member
2 years 7 months ago #295273 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
The OP has describe a robust installation method within the opening couple of posts. Having tested both methods for the RPi5, the Raspbian OS based method appears to be the better setup.
2 years 4 months ago #303453 by cakeslob
elovalvo, where can I find youre raspian12 bookworm image for the rpi4? is it the same as rpi5? I went searching through a bunch of threads but cannot find RPi4
2 years 4 months ago #303495 by elovalvo
No, the images are different.
If you wait a couple of days I can create updated ones for both versions of Raspberry
The following user(s) said Thank You: cakeslob
Time to create page: 0.146 seconds
