- Thank you received: 426
Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
2 years 11 months ago #285587
Replied by Cant do this anymore bye all on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Man I'm having a hell of a time getting an real time kernel to boot on my RPi5, any chance of sharing your image ?
rpi-image-builder was no good either
- Thank you received: 4153
2 years 11 months ago #285591
Replied by rodw on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Hmm, Cornelius upstream added preliminary support for the 5b in early october.
github.com/pyavitz/rpi-img-builder
the commit is at github.com/pyavitz/rpi-img-builder/commi...a0b81cf61efcf56500ea
Maybe its time to merge upstream into my repo. Then just change the board when building and it should work
I may have time later tonight to give that a go.
2 years 11 months ago #285594
Preformed a git pull and had no luck
got "running /scripts/local/block" loop
Building a non-realtime kernel natively ATM using the script above to see how we go. If that boots I'll try a building a real time kernel.
Is it the branding that prevent us from distributing a image based on the Raspbain-OS ?
- elovalvo
- Thank you received: 127
2 years 11 months ago #285603
by elovalvo
Replied by elovalvo on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Are you addressing me?Man I'm having a hell of a time getting an real time kernel to boot on my RPi5, any chance of sharing your image ?
2 years 11 months ago #285610
Sorry both you & rodw.
2 years 11 months ago #285613
Not me....
But....
I have synced my repo with upstream and they say the pi5 is supported now in the image builder we use.
I am building an image for the Pi5 as we speak.
The kernel built OK but I may have had an error building the root file system. Checking again.
If I have any luck, I will share a file.
But....
