Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
2 years 4 months ago - 2 years 4 months ago #303696 by elovalvo
No, the images are different.
If you wait a couple of days I can create updated ones for both versions of Raspberry
Here are the files I promised you
drive.google.com/file/d/1jBEO7Acl0C0t4id.../view?usp=drive_link  (Pi5 - kernel-6.6.32-v8-16k-elv.zip)
drive.google.com/file/d/1B58q4xJgBR4GnxI.../view?usp=drive_link  (Pi4, Pi400 - kernel-6.6.32-v8-elv.zip)
drive.google.com/file/d/1ltrkbEiI_BssNY0.../view?usp=drive_link (install-kernel)
Since for building the RT kernel I followed this procedure ( forums.raspberrypi.com/viewtopic.php?t=343387 ), in the next post I describe the procedures for using.
Last edit: 2 years 4 months ago by elovalvo.
The following user(s) said Thank You: cakeslob
2 years 4 months ago - 2 years 4 months ago #303697 by elovalvo
To install raspian12 bookworm image, prepare an SD card with the RaspiOS version for the type of Raspberry you are interested in (pi4, Pi400, Pi5).
I find it comfortable
www.raspberrypi.com/software/
because it also allows you to select various options (ssh, wifi, locales, etc..).
Boot the SD and run these commands from the terminal to update the RaspiOS version
sudo apt-get update sudo apt-get upgrade sudo reboot
Upon reboot, copy the install-kernel files and the zip file to the /tmp directory
Then run these commands from terminal
cd /tmp chmod +x ./install-kernel sudo ./install-kernel ./kernel-6.6.32-v8-elv.zip
(in the case of Pi4 and PI400)
or
sudo ./install-kernel ./kernel-6.6.32-v8-16k-elv.zip
(in the case of Pi5)
So you need to edit the cmdline.txt with
sudo nano "/boot/firmware/cmdline.txt"
adding the following commands to the end of the line
isolcpus=2,3 rcu_nocbs=2,3 nohz_full=2,3 max.processor.cstate=1
The following user(s) said Thank You: cakeslob, Cant do this anymore bye all
2 years 4 months ago #303721 by cakeslob
alright, awesome thank you!
question, your previous images had the rt already installed, is there some limitation to why they arent this time, or is it so you can hit update before loading the kernel?
2 years 4 months ago #303752 by elovalvo
I chose this procedure because it allows you to choose the best Raspbian configuration (user, password, ssh, wifi, locales, etc..), to update an already existing version, to install the version of LinuxCNC of your choice and other alternatives.
However, for those who don't want to, in these links there are the ready-to-user images with LinuxCNC 2.9.2
(user:pi  pwd:raspberry)
OS: Linux raspberrypi 6.6.32-rpi999-rpi-v8 #1 SMP PREEMPT_RT Mon Jun 24 15:56:31 CEST 2024 aarch64
( image_lcnc_pi4.zip )
OS: Linux raspberrypi 6.6.32-rpi999-rpi-2712 #2 SMP PREEMPT_RT Sun Jun  9 10:10:54 CEST 2024 aarch64
( image_lcnc_pi5.zip )
The following user(s) said Thank You: cakeslob, rdtsc
  • Platinum Member
  • Platinum Member
2 years 4 months ago #303761 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Comparison between Raspian 12 Bookworm on Raspberry Pi 4 and Raspberry Pi 5
Another note if you want\need to run Axis you’ll want to use raspi-config to change from wayland to x11. Or anything that depends on the X11 libs, I found the way land compatibility layer really really slow.
The following user(s) said Thank You: elovalvo, cakeslob, rdtsc
  • Platinum Member
  • Platinum Member
2 years 3 months ago #304364 by Cant do this anymore bye all
Awesome used all of elovalo bits to setup an Rpi5 with Pineberry NVME hat, works great.
The following user(s) said Thank You: tommylight, elovalvo
Time to create page: 0.134 seconds
