Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
2 years 9 months ago - 2 years 9 months ago #290759 by U2fletch
I have a Pi 400 and the image loads fine. I have sound, and can confirm that it runs great on my setup.  Had a minor hiccup with my Mesa 7i96s board. I could ping the board at address 10.10.10.10, but when I started LinuxCNC I got the "temporarily unavaliable" error. Had to go configure my network settings. Once that was set everything works great.  Thanks!
Last edit: 2 years 9 months ago by U2fletch. Reason: Had wrong image loaded
2 years 9 months ago #292108 by itai
I want to use Raspberry PI 4 + LinuxCNC-RIO (Tangoboard) with SPI connection.
How can I enable SPI (using the IO pins) with the LinuxCNC image?
How can I disable the automatic screen lock?
Thanks,
-- Itai
2 years 8 months ago #292898 by Wierzbowski
hi, could You please make step-by-step video guide for newbies how to setup raspberry pi 400/4b in order to controll cnc machine?
2 years 8 months ago - 2 years 8 months ago #292903 by rodw
I can't cos I don't have a pi.  But do this:
Download the iamge
Burn do a SD card using  Balena Etcher (free download windows and linux)
Boot the pi using the SD card
Log in with username/password cnc/cnc
open a terminal
type: sudo menu-config
and set up your wifi if required, locale and time zone etc. You can also change your password.
After that you have a computer with linuxcnc installed so simply refer to the docs on the LinuxCNC web site. There is a specific gpio driver for the Pi that is documented there. There is also a pi specific Mesa card but I would recommend you use a Mesa Ethernet card for future flexibility.
You can also install ethercat if you want to use it but thats not a beginners path
sudo apt install linuxcnc-ethercat (from memory)
Last edit: 2 years 8 months ago by rodw.
The following user(s) said Thank You: Wierzbowski
2 years 6 months ago #298382 by xenon-alien
Hello.
Sorry that I'm asking 2nd time, but...
How can I change the resolution, orientation (+touch) and make it sound?
I have a 10.1" IPS Touch display with resolution 1920x1200 @60 Hz + audio speakers.
But there is no sound, the resolution is only 1920x1080, no possibility to rotate the screen.
Is it possible to make it work?
On a Windows system the display works fine. (even tried on the Orange Pi PC with Armbian and it almost worked)
My config.txt file
arm_64bit=1 initramfs initrd.gz followkernel # uncomment if you get no picture on HDMI for a default "safe" mode #hdmi_safe=1 # uncomment this if your display has a black border of unused pixels visible # and your display can output without overscan disable_overscan=1 # uncomment the following to adjust overscan. Use positive numbers if console # goes off screen, and negative if there is too much border #overscan_left=16 #overscan_right=16 #overscan_top=16 #overscan_bottom=16 # uncomment to force a console size. By default it will be display's size minus # overscan. framebuffer_width=1920 framebuffer_height=1200 # uncomment if hdmi display is not detected and composite is being output hdmi_force_hotplug=1 # uncomment to force a specific HDMI mode (this will force VGA) hdmi_group=2 hdmi_mode=87 hdmi_cvt=1920 1200 60 5 0 0 0 # uncomment to force a HDMI mode rather than DVI. This can make audio work in # DMT (computer monitor) modes hdmi_drive=2 # uncomment to increase signal to HDMI, if you have interference, blanking, or # no display #config_hdmi_boost=4 # uncomment for composite PAL #sdtv_mode=2 # camera #start_x=1 #gpu_mem=128 # automatically load overlays for detected cameras #camera_auto_detect=1 # automatically load overlays for detected DSI displays #display_auto_detect=1 # uncomment to overclock: https://www.tomshardware.com/how-to/overclock-any-raspberry-pi #arm_freq= #gpu_freq= #core_freq= #over_voltage= #force_turbo=1 # uncomment some or all of these to enable the optional hardware interfaces #dtparam=i2c_arm=on #dtparam=i2s=on #dtparam=spi=on # uncomment this to enable infrared communication. #dtoverlay=gpio-ir,gpio_pin=17 #dtoverlay=gpio-ir-tx,gpio_pin=18 # additional overlays and parameters are documented /boot/overlays/README # enable audio (loads snd_bcm2835) dtparam=audio=on # enable uart enable_uart=0 # disable wifi and bluetooth #dtoverlay=disable-wifi #dtoverlay=disable-bt #dtoverlay=pi3-disable-wifi #dtoverlay=pi3-disable-bt # remove test rainbow disable_splash=1 # disables the warning overlays #avoid_warnings=1 [cm4] # Enable host mode on the 2711 built-in XHCI USB controller. # This line should be removed if the legacy DWC2 controller is required # (e.g. for USB device mode) or if USB support is not required. otg_mode=1 [pi4] # enable DRM VC4 V3D driver on top of the dispmanx display stack dtoverlay=vc4-kms-v3d #dtoverlay=vc4-fkms-v3d max_framebuffers=2 arm_boost=1 max_usb_current=1
2 years 6 months ago #298385 by elovalvo
Hello.
forum.linuxcnc.org/9-installing-linuxcnc...i-5?start=190#298380
Time to create page: 0.442 seconds
