Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
2 years 2 months ago #306872 by cncmiljc
Could anyone help, I made the image for the pi4 following the image on the official page, but it doesn't have the area for ethernet configuration, how can I solve this problem?
2 years 2 months ago #306884 by rodw
The current 2.9.2 image  needs updating to 2.9.3 but we no longer install Ethercat repositories for the Raspberry pi.
I am not sure if the pi is supported in their repos for Debian 12 at all
Also I doubt that a linuxcnc-ethercat driver is built for the pi either
Right now your option is to build from source
I have raised an issue with Ethercat to explore a solution for this.
2 years 2 months ago #306886 by cncmiljc
In my case, it would be ethernet, I need the configuration area for the IP/Gateway address, that way, I can study the connection with ethernet cards.
2 years 2 months ago #306887 by rodw
read the comments on the downloads page. menu-config should do it for you.
2 years 2 months ago #307541 by rodw
updated for Linuxcnc 2.9.3
Newer kernel 6.6.44
Better screen support for the Pi5
Now includes ethercat repos. Following the sticky in th eethercat section to install/
Pi 5 Image  drive.google.com/file/d/1iwQpbMoNdI6wnv7...MyZ/view?usp=sharing
Pi4 Image  drive.google.com/file/d/1Fg2CPTezUyrRFrO...ytT/view?usp=sharing
The following user(s) said Thank You: Aciera, flyingbrick
2 years 2 months ago #307542 by rodw
The first post has been updated to include images for 2.9.3.
The Pi 5 is tested and working.
Any feedback about the Pi4 would be appreciated
Time to create page: 0.106 seconds
