Linuxcnc 2.9.2 and 2.93 images for Raspberry Pi 4b & 5
2 years 3 weeks ago #311659 by xenon-alien
I did something, to display the correct time choosing Kyiv (Ukraine) in local.... something (and want to use other languages to type and search on the internet)
May be that was the cause?
2 years 3 weeks ago #311819 by xenon-alien
Can you tell me how can I rotate the touch part of the screen too?
Try this, otherwise it is a mess to sift through endless posts on several forums to get the right answer, been there and done that, twice.
gist.github.com/mildmojo/48e9025070a2ba40795c
Do I have to return it in landscape mode before rotating it with this script?
2 years 3 weeks ago #311829 by tommylight
No, it should do the rotation of both the screen and touch.
At least that is what it says, i have not used it, i did it the old way and it is long and painful, so if this works, do report back, please.
2 years 2 weeks ago - 2 years 2 weeks ago #311865 by xenon-alien
You confused me...
If it will rotate both, I need to change it from portrait orientation back again to landscape and only after that use the script.
Is it correct?
Because it's now in portrait mode and the touch works not correctly. (as on the photo above)
Last edit: 2 years 2 weeks ago by xenon-alien.
2 years 2 weeks ago #311869 by tommylight
From the link
Rotates modern Linux desktop screen and input devices to match.
Time to create page: 0.459 seconds
