- Thank you received: 72
Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
- fletch
1 year 6 months ago - 1 year 6 months ago #326959
by fletch
Replied by fletch on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Just for completeness and to save anyone having to mess around with compiling kernel modules, here is what looks like a fairly comprehensive (at least until 6.13) list of in-kernel USB WiFi devices:
github.com/morrownr/USB-WiFi/blob/main/h...in-kernel_drivers.md
Discovered it a little late but I think only one has an RP-SMA connection.
Last edit: 1 year 6 months ago by fletch.
The following user(s) said Thank You: unknown
- unknown
- Thank you received: 323
1 year 6 months ago #326960
by unknown
Replied by unknown on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Dunn why RPi doesn't add a connector for an external antenna.
- fletch
1 year 6 months ago #326961
by fletch
That would be lovely - the CM5 has one but then you need a carrier board and I don't know if the LinuxCNC image would run on the CM5/eMMC? With the right carrier board would be perfect though...
- ErwinCNC
1 year 6 months ago #327134
by ErwinCNC
Replied by ErwinCNC on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
Hello
I put my pi 5 into operation yesterday.
Unfortunately I get the locale error with Pconf
I tried to use the same settings as you.
My keyboard is german
Do you have an idea?
- 3404gerber
- Thank you received: 14
1 year 6 months ago #327135
by 3404gerber
Replied by 3404gerber on topic Linuxcnc & the Raspberry Pi (4 & 5) Official Images Only!!!
I have a LinuxCNC image running on a CM4/eMMC, so it should also work on the Pi5.
- unknown
1 year 6 months ago #327139
by unknown
If you're going to use a CM5 & carrier board you'd be crazy not to use an NVMe drive. It's fast, like really fast. I use one with mine Rpi5.
Time to create page: 0.251 seconds
