Yes, I launched the included Axis sims on a dell OptiPlex-7780-AIO Intel Core i7-10700.
This ssd has debian 12 and mx23, does this affect mint 22.1?
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.10.0~pre0
Machine configuration directory is '/home/gitin/linuxcnc/configs/sim.axis-1'
Machine configuration file is 'axis_mm.ini'
INIFILE=/home/gitin/linuxcnc/configs/sim.axis-1/axis_mm.ini
VERSION=1.1
PARAMETER_FILE=sim_mm.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=X Y Z
KINEMATICS=trivkins
Starting LinuxCNC...
linuxcncsvr (2832) emcsvr: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
milltask (2845) task: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
halui (2847) halui: machine 'LinuxCNC-HAL-SIM-AXIS' version '1.1'
Found file(lib): /usr/share/linuxcnc/hallib/core_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/sim_spindle_encoder.hal
Found file(lib): /usr/share/linuxcnc/hallib/axis_manualtoolchange.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Found file(REL): ./cooling.hal
USRMOT: ERROR: command 30 timeout
emcMotionInit: emcTrajInit failed
Starting DISPLAY program: axis
task: 0 cycles, min=0.000002, max=0.001060, avg=-1.000000, 0 latency excursions (> 10x expected cycle time of 0.001000s)
Debug file information:
Note: Using POSIX realtime
link (updating variable file): Нет такого файла или каталога
File "/usr/bin/axis", line 3007, in <module>
vars = nf.Variables(root_window,
File "/usr/lib/python3/dist-packages/nf.py", line 46, in __init__
setattr(self, name, makevar(master, name, klass))
File "/usr/lib/python3/dist-packages/nf.py", line 70, in makevar
self.set(self._default)
File "/usr/lib/python3.12/tkinter/__init__.py", line 424, in set
return self._tk.globalsetvar(self._name, value)
_tkinter.TclError: can't set "taskfile": can't read "::": no such variable
2835
2845
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Пн 17 мар 2025 19:59:24 MSK
UTC Date: Пн 17 мар 2025 16:59:24 UTC
this program: /usr/bin/linuxcnc_info
uptime: 19:59:24 up 4 min, 1 user, load average: 1,03, 0,92, 0,43
lsb_release -sa: Linuxmint Linux Mint 22.1 22.1 xia
linuxcnc: /usr/bin/linuxcnc
pwd: /home/gitin/linuxcnc/configs/sim.axis-1
USER: gitin
LOGNAME: gitin
HOME: /home/gitin
EDITOR:
VISUAL:
LANGUAGE: ru_RU
TERM: dumb
COLORTERM:
DISPLAY: :0
DESKTOP: mate
display size: 1920x1080 pixels (508x285 millimeters)
PATH: /usr/bin:/home/gitin/linuxcnc/configs/sim.axis-1/bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
uname items:
nodename -n: gitin-OptiPlex-7780-AIO
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.10.12-1 (2024-10-01)
machine -m: x86_64
processor -p: x86_64
platform -i: x86_64
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.10.12-rt-amd64 root=UUID=0ae8aa4a-3b74-4dae-9243-989492bb833f ro quiet splash
model name: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
cores: 8
cpu MHz: 4558.254
parport:
serial: 0000-0000 : serial
Versions:
gcc: gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
python: Python 3.12.3
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.10.0~pre0
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Желаемый=неизвестно
/установить/удалить[r]/вычистить[p]/зафиксировать[h]
| Состояние=не[n]/установлен/настроен[c]/распакован/частично настроен[F]/
частично установлен[H]/trig-aWait/Trig-pend
|/ Ошибка?
нет)/требуется переустановка[R] (верхний регистр
в полях состояния и ошибки указывает на ненормальную ситуацию)
||/ Имя Версия Архитектура Описание
un linuxcnc <нет> <нет> (описание недоступно)
un linuxcnc-dev <нет> <нет> (описание недоступно)
un linuxcnc-doc <нет> <нет> (описание недоступно)
un linuxcnc-doc-en <нет> <нет> (описание недоступно)
un linuxcnc-doc-es <нет> <нет> (описание недоступно)
un linuxcnc-doc-fr <нет> <нет> (описание недоступно)
un linuxcnc-sim <нет> <нет> (описание недоступно)
un linuxcnc-sim-dev <нет> <нет> (описание недоступно)
ii linuxcnc-uspace 1:2.10.0~pre0 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.10.0~pre0 amd64 PC based motion controller for real-time Linux
