Linux_Mint_22.1_LinuxCNC_2.10.iso
1 year 2 weeks ago #336648 by billykid
Hi Tom, after a few months I tried installing this ISO again and everything works even with my old configurations. The only problem is the green spindle speed bar going backwards but the numbers are correct. When stopped the bar is all green then as you increase the rpm it decreases until it reaches the maximum, LinuxCNC crashes and says: spindle speed out of range.
1 year 2 weeks ago #336662 by tommylight
That should not be a distro issue, but a config issue, so do start a new topic and upload both configs so we can have a look.
3 months 2 weeks ago #347706 by BlownCorona
Good evening
I've been using this iso successfully for a while now, i picked up a nice touch screen that works, but would work a lot better if i installed the displaylink drivers. Problem is that when installing this, i get an error that the linux headers are missing.
Ive tried many of the usual commands to load the headers and nothing seems to be able to find the matching file. Have you got any insight or suggestions?
If you would like specific error messages i can go through the motions and record these for you.
Cheers!
3 months 2 weeks ago #347707 by tommylight
sudo apt update && sudo apt install linux-headers-$(uname -r)
3 months 2 weeks ago #347731 by BlownCorona
that is essentially the commands Ive been trying.
below shows the error that keeps cropping up
Ign:1 http://packages.linuxmint.com xia InRelease                                   Hit:2 http://archive.ubuntu.com/ubuntu noble InRelease                              Hit:3 https://www.synaptics.com/sites/default/files/Ubuntu stable InRelease         Hit:4 http://packages.linuxmint.com xia Release                                     Get:5 http://security.ubuntu.com/ubuntu noble-security InRelease [126 kB]           Get:6 http://archive.ubuntu.com/ubuntu noble-updates InRelease [126 kB]        Hit:8 https://ppa.launchpadcontent.net/freecad-maintainers/freecad-stable/ubuntu noble InRelease Get:9 http://archive.ubuntu.com/ubuntu noble-backports InRelease [126 kB]           Get:10 http://security.ubuntu.com/ubuntu noble-security/main amd64 Components [44.8 kB] Get:11 http://archive.ubuntu.com/ubuntu noble-updates/main i386 Packages [517 kB] Get:12 http://security.ubuntu.com/ubuntu noble-security/universe amd64 Components [76.3 kB] Get:13 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 Packages [1,092 kB] Get:14 http://archive.ubuntu.com/ubuntu noble-updates/main amd64 Components [181 kB] Get:15 http://archive.ubuntu.com/ubuntu noble-updates/universe i386 Packages [1,130 kB] Get:16 http://archive.ubuntu.com/ubuntu noble-updates/universe amd64 Packages [1,660 kB] Get:17 http://archive.ubuntu.com/ubuntu noble-updates/universe amd64 Components [388 kB] Get:18 http://archive.ubuntu.com/ubuntu noble-updates/multiverse amd64 Components [940 B] Get:19 http://archive.ubuntu.com/ubuntu noble-backports/main amd64 Components [5,744 B] Get:20 http://archive.ubuntu.com/ubuntu noble-backports/universe amd64 Components [10.5 kB] Fetched 5,484 kB in 5s (1,023 kB/s)                                   Reading package lists... Done Building dependency tree... Done Reading state information... Done 2 packages can be upgraded. Run 'apt list --upgradable' to see them. Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package linux-headers-6.13-rt-amd64 E: Couldn't find any package by glob 'linux-headers-6.13-rt-amd64'
i havn't been able to manually find a matching header either,  only some very close but older revisions and i dont know enough about linux to go about building it up to suit the above revision, or if thats even something that could be done.
3 months 2 weeks ago #347738 by rodw
I might be wrong as I have only used Debian for years because Mint let me down a few years ago when Python 3 became mandatory for Linuxcnc and have not researched this for you.
I have a feeling that 6.13 is not a standard kernel used by Debian and therefore its derivatives. I believe that 6.12 was a release version.
So if it was not released, there won't be a readymade set of headers so you would need to compile the kernel to a Deb file which will output the headers as a Deb to install.
Debian is a much easier path. Just install the Cinamon desktop on install and you'll hardly miss Mint.
The following user(s) said Thank You: BlownCorona
Time to create page: 0.071 seconds
