Mesa Configuration Tool
- AirRacer
- Thank you received: 3
09 Jul 2025 06:30 - 09 Jul 2025 15:12 #331557
by AirRacer
Replied by AirRacer on topic Mesa Configuration Tool
I’ve just discovered that the Mesa Configuration Tool (at least the version available prior to 8/19/2024) does not configure the manual tool change section correctly. I recently discovered this when my file did not stop at the M6 command and continued on to the next set of code. I was able to look at a .hal file set up with pncconfig and copy the manual tool change section from there and now everything works correctly (I get the manual tool change pop up window when the M6 command is encountered). This is a Mill setup that uses the AXIS GUI.
Here are the two configurations:
Pncconfig version that works:
# ---manual tool change signals---
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-number <= iocontrol.0.tool-prep-number
# ---Use external manual tool change dialog---
net tool-change-request => hal_manualtoolchange.change
net tool-change-confirmed <= hal_manualtoolchange.changed
net tool-number => hal_manualtoolchange.number
# ---ignore tool prepare requests---
Mesa Configuration Tool version that doesn’t invoke the manual tool change pop-up or pause the code at M6:
# Manual Tool Change Dialog
# create signals for tool loading loopback
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
net tool-change-loop iocontrol.0.tool-change => iocontrol.0.tool-changed
Regards,
Skylor
Regards,
Skylor
Last edit: 09 Jul 2025 15:12 by AirRacer.
- JT
- Thank you received: 593
15 Jul 2025 14:09 #331855
by JT
Replied by JT on topic Mesa Configuration Tool
Thanks for the report, this has been fixed.
JT
JT
The following user(s) said Thank You: AirRacer
- ZXT
20 Jul 2025 13:17 - 20 Jul 2025 14:49 #332056
by ZXT
Replied by ZXT on topic Mesa Configuration Tool
Hello guys! I've just noticed that I/O map for 7i95T from Mesa Configuration tool 2.1.7 is not complete.
The I/O map is missing connector TB5 and TB6 or am i just looking at it wrong?
Or is it because I'll have to configure inputs & outputs under the 7i95t tab to get pin names in my I/O.hal?
Firmware: 7i95t_1pwmd.bin
Configuration Name: HOSTMOT2
BoardName : MESA7I95
FPGA Size: 20 KGates
FPGA Pins: 256
Number of IO Ports: 2
Width of one I/O port: 29
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 6 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: SSR
There are 1 of SSR in configuration
Version: 0
Registers: 2
BaseAddress: 7D00
Module: InMux
There are 1 of InMux in configuration
Version: 0
Registers: 5
BaseAddress: 8000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for Step/DIR+Serial+Encoders -> 7I95_0
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
TB3-2,3 0 IOPort StepGen 0 Step/Table1 (Out)
TB3-4,5 1 IOPort StepGen 0 Dir/Table2 (Out)
TB3-8,9 2 IOPort StepGen 1 Step/Table1 (Out)
TB3-10,11 3 IOPort StepGen 1 Dir/Table2 (Out)
TB3-14,15 4 IOPort StepGen 2 Step/Table1 (Out)
TB3-16,17 5 IOPort StepGen 2 Dir/Table2 (Out)
TB3-20,21 6 IOPort StepGen 3 Step/Table1 (Out)
TB3-22,23 7 IOPort StepGen 3 Dir/Table2 (Out)
TB4-2,3 8 IOPort StepGen 4 Step/Table1 (Out)
TB4-4,5 9 IOPort StepGen 4 Dir/Table2 (Out)
TB4-8,9 10 IOPort PWM 0 PWM (Out)
TB4-10,11 11 IOPort PWM 0 Dir (Out)
TB2-14,15 12 IOPort SSerial 0 RXData0 (In)
TB4-16,17 13 IOPort SSerial 0 TXData0 (Out)
Internal 14 IOPort SSerial 0 TXEn0 (Out)
TB4-20,21 15 IOPort SSerial 0 RXData1 (In)
TB4-22,23 16 IOPort SSerial 0 TXData1 (Out)
Internal 17 IOPort SSerial 0 TXEn1 (Out)
TB1-1,2,9,10 18 IOPort MuxedQCount 0 MuxQ-A (In)
TB1-4,5,12,13 19 IOPort MuxedQCount 0 MuxQ-B (In)
TB1-7,8,15,16 20 IOPort MuxedQCount 0 MuxQ-IDX (In)
TB1-17,18 TB2-1,2 21 IOPort MuxedQCount 1 MuxQ-A (In)
TB1-20,21 TB2-4,5 22 IOPort MuxedQCount 1 MuxQ-B (In)
TB1-23,24,TB2-7,8 23 IOPort MuxedQCount 1 MuxQ-IDX (In)
TB2-9,10,17,18 24 IOPort MuxedQCount 2 MuxQ-A (In)
TB2-11,12,20,21 25 IOPort MuxedQCount 2 MuxQ-B (In)
TB2-15,16,23,24 26 IOPort MuxedQCount 2 MuxQ-IDX (In)
Internal 27 IOPort MuxedQCountSel 0 MuxSel0 (Out)
Internal 28 IOPort InMux 0 Addr0 (Out)
IO Connections for I/O+Expansion -> 7I95_1
Internal 29 IOPort InMux 0 Addr1 (Out)
Internal 30 IOPort InMux 0 Addr2 (Out)
Internal 31 IOPort InMux 0 Addr3 (Out)
Internal 32 IOPort InMux 0 Addr4 (Out)
Internal 33 IOPort InMux 0 Data0 (In)
TB3-13,14 34 IOPort SSR 0 Out-00 (Out)
TB3-15,16 35 IOPort SSR 0 Out-01 (Out)
TB3-17,18 36 IOPort SSR 0 Out-02 (Out)
TB3-19,20 37 IOPort SSR 0 Out-03 (Out)
TB3-21,22 38 IOPort SSR 0 Out-04 (Out)
TB3-23,24 39 IOPort SSR 0 Out-05 (Out)
Internal 40 IOPort SSR 0 AC Ref (Out)
P1-01/DB25-01 41 IOPort None
P1-02/DB25-14 42 IOPort None
P1-03/DB25-02 43 IOPort None
P1-04/DB25-15 44 IOPort None
P1-05/DB25-03 45 IOPort None
P1-06/DB25-16 46 IOPort None
P1-07/DB25-04 47 IOPort None
P1-08/DB25-17 48 IOPort None
P1-09/DB25-05 49 IOPort None
P1-11/DB25-06 50 IOPort None
P1-13/DB25-07 51 IOPort None
P1-15/DB25-08 52 IOPort None
P1-17/DB25-09 53 IOPort None
P1-19/DB25-10 54 IOPort None
P1-21/DB25-11 55 IOPort None
P1-23/DB25-12 56 IOPort None
P1-25/DB25-13 57 IOPort None
Last edit: 20 Jul 2025 14:49 by JT. Reason: add code tags
- JT
20 Jul 2025 14:47 #332062
by JT
It's a mystery to me, that's what the mesaflash command returns
Maybe PCW can shed some light on that?
JT
mesaflash --addr 10.10.10.10 --device 7i95t --readhmidMaybe PCW can shed some light on that?
JT
- Thank you received: 5326
20 Jul 2025 15:05 - 20 Jul 2025 15:57 #332063
Replied by PCW on topic Mesa Configuration Tool
The 24 isolated inputs are all controlled by the inmux pins.
I guess they could be named "TB5-1,12, TB6-1,24" rather than "internal"
in mesaflash...
Edit: pushed a change to mesaflash to rename 7I95/7I97/7C80 "internal"
pins to more informative names.
in mesaflash...
Last edit: 20 Jul 2025 15:57 by PCW.
The following user(s) said Thank You: tommylight, JT
- ZXT
20 Jul 2025 19:50 #332080
by ZXT
Managed to get info by making a test config in MesaCT and then look in I/O.hal
Input 16, TB5
hm2_7i95.0.inmux.00.input-16
Input 16, TB5
20 Jul 2025 23:32 #332090
You can also get a list of all enabled hardware pins with:
halcmd show all | grep hm2
When LinuxCNC is running.
The following user(s) said Thank You: JT, ZXT
- LearningLinuxCNC
- Thank you received: 39
06 Dec 2025 02:42 #339780
by LearningLinuxCNC
Replied by LearningLinuxCNC on topic Mesa Configuration Tool
I did not get a working stepper configuration out of MesaCT with a 7i76eu. I have posted the output and my working config here forum.linuxcnc.org/configuration-tools/5...erated-configuration
The output was supposed to be on the 02 stepper but it was connected to the 00 stepper. The feedback loop was not closed and it was not set to be in velocity mode. Look at the two configurations.
- JT
09 Dec 2025 12:47 #339911
by JT
I fixed the missing 7i76eu from the stepper boards variable which caused a partial build of the main.hal file and leaving out the enable and the stepper setp lines.
JT
JT
- 5_Zylinder
03 Jan 2026 19:33 #340927
by 5_Zylinder
Replied by 5_Zylinder on topic Mesa Configuration Tool
Hello,
I installed Debian 13 (Trixie) and the latest Linux CNC 2.9.8 today. Unfortunately, the Mesa Configuration tool won't install.
I get the message: mesact: Depends: phyton3-distro but it is not installable. Perhaps someone could give me an additional tip.
Time to create page: 1.325 seconds
