- Thank you received: 276
Ethercat HAL driver
- db1981
5 years 8 months ago #199746
by db1981
Replied by db1981 on topic Ethercat HAL driver
@bkt
sorry forget it.
I've got the same proplem by testing now.
Beckhoff changed the Pdo configuration between firmware 0024 and 0025. This will not work at the moment.
I will discuss this with sascha tomorrow.
sorry forget it.
The following user(s) said Thank You: bkt
- bkt
- Thank you received: 114
5 years 8 months ago #199748
by bkt
Replied by bkt on topic Ethercat HAL driver
Seems I'm a very lucky man.
....... Thanks for the advice and I hope in your or Chimeno help tomorrow.
Good Night
Good Night
- db1981
5 years 8 months ago #199751
by db1981
the changes for this are only to edit 4 lines of codes, but then it is hardcoded for this revision of the card.
because of that this will not stay an single case in the future, we should implement an solution in lcec_conf for handling/detect this firmware rev. stuff.
- bkt
5 years 8 months ago - 5 years 8 months ago #199801
by bkt
does this mean that you will need to create an xml file specifically for the el5151 element? Or more clean solution is write a new custom driver called el5151_25 and use it on my xml instead the old one?
P.S.: I launch these command: ethercat xml -p6 (my el5151) and obtain these xml
The problem is ethercat-xml see SubIdx=20 and SubIdx=17 as UINT32 but on ethrcat-pdos command these SubIdx seems nr.11 and 14? is these the problem? Different number of SubIdx detected or stored?
If I read lcec_el5151.c I see these part:
That is the same thart i see on ethercet configurator .... same idx, same pin, same data type .... so seems lcec_el5151.c was ok .... but these part is no understand from my side, so not understand if work or not for me:
I appreciate some little expalanation so maybe I have some ideas about.
bkt
db1981 wrote: but then it is hardcoded for this revision of the card.
Warning: Spoiler!
<?xml version="1.0" ?>
<EtherCATInfo>
<!-- Slave 6 -->
<Vendor>
<Id>2</Id>
</Vendor>
<Descriptions>
<Devices>
<Device>
<Type ProductCode="#x141f3052" RevisionNo="#x00190000">EL5151</Type>
<Name><![CDATA[EL5151 1K. Inc. Encoder]]></Name>
<Sm Enable="1" StartAddress="#x1000" ControlByte="#x26" DefaultSize="128" />
<Sm Enable="1" StartAddress="#x1080" ControlByte="#x22" DefaultSize="128" />
<Sm Enable="1" StartAddress="#x1100" ControlByte="#x24" DefaultSize="6" />
<Sm Enable="1" StartAddress="#x1180" ControlByte="#x20" DefaultSize="14" />
<RxPdo Sm="2" Fixed="1" Mandatory="1">
<Index>#x1600</Index>
<Name></Name>
<Entry>
<Index>#x7000</Index>
<SubIndex>1</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
<DataType>BOOL</DataType>
</Entry>
<Entry>
<SubIndex>2</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<SubIndex>3</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<SubIndex>4</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<Index>#x0000</Index>
<BitLen>4</BitLen>
</Entry>
<Entry>
<BitLen>8</BitLen>
</Entry>
<Entry>
<SubIndex>17</SubIndex>
<BitLen>32</BitLen>
<Name></Name>
<DataType>UINT32</DataType>
</Entry>
</RxPdo>
<TxPdo Sm="3" Fixed="1" Mandatory="1">
<Index>#x1a00</Index>
<Name></Name>
<Entry>
<Index>#x6000</Index>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<BitLen>4</BitLen>
</Entry>
<Entry>
<SubIndex>8</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<SubIndex>9</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<SubIndex>10</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<SubIndex>11</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<BitLen>1</BitLen>
</Entry>
<Entry>
<SubIndex>13</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<SubIndex>14</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<BitLen>1</BitLen>
</Entry>
<Entry>
<SubIndex>16</SubIndex>
<BitLen>1</BitLen>
<Name></Name>
</Entry>
<Entry>
<BitLen>32</BitLen>
<Name></Name>
</Entry>
<Entry>
<SubIndex>18</SubIndex>
<BitLen>32</BitLen>
<Name></Name>
</Entry>
</TxPdo>
<Index>#x1a02</Index>
<Name></Name>
<Entry>
<SubIndex>20</SubIndex>
<BitLen>32</BitLen>
<Name></Name>
</Entry>
</TxPdo>
</Device>
</Devices>
</Descriptions>
</EtherCATInfo>
Warning: Spoiler!
static ec_pdo_entry_info_t lcec_el5151_in[] = {
{0x6000, 0x01, 1}, // Latch C valid
{0x6000, 0x02, 1}, // Latch extern valid
{0x6000, 0x03, 1}, // Set counter done
{0x0000, 0x00, 4}, // Gap
{0x6000, 0x08, 1}, // Extrapolation stall
{0x6000, 0x09, 1}, // Status of input A
{0x6000, 0x0a, 1}, // Status of input B
{0x6000, 0x0b, 1}, // Status of input C
{0x0000, 0x00, 1}, // Gap
{0x6000, 0x0d, 1}, // Status of extern latch
{0x1c32, 0x20, 1}, // Sync error
{0x1800, 0x09, 1}, // TxPDO Toggle
{0x6000, 0x11, 32}, // Counter value
{0x6000, 0x12, 32} // Latch value
static ec_pdo_entry_info_t lcec_el5151_period[] = {
{0x6000, 0x14, 32} // Period value
static ec_pdo_entry_info_t lcec_el5151_out[] = {
{0x7000, 0x01, 1}, // Enable latch C
{0x7000, 0x02, 1}, // Enable latch extern on positive edge
{0x7000, 0x03, 1}, // Set counter
{0x7000, 0x04, 1}, // Enable latch extern on negative edge
{0x0000, 0x00, 8}, // Gap
{0x7000, 0x11, 32} // Set counter value
static ec_pdo_info_t lcec_el5151_pdos_out[] = {
{0x1600, 7, lcec_el5151_out}
static ec_pdo_info_t lcec_el5151_pdos_in[] = {
{0x1A00, 15, lcec_el5151_in},
{0x1A02, 1, lcec_el5151_period}
Warning: Spoiler!
// initialize POD entries
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x01, &hal_data->latch_c_valid_pdo_os, &hal_data->latch_c_valid_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x02, &hal_data->latch_ext_valid_pdo_os, &hal_data->latch_ext_valid_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x03, &hal_data->set_count_done_pdo_os, &hal_data->set_count_done_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x08, &hal_data->expol_stall_pdo_os, &hal_data->expol_stall_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x09, &hal_data->ina_pdo_os, &hal_data->ina_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x0a, &hal_data->inb_pdo_os, &hal_data->inb_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x0b, &hal_data->inc_pdo_os, &hal_data->inc_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x0d, &hal_data->inext_pdo_os, &hal_data->inext_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x1c32, 0x20, &hal_data->sync_err_pdo_os, &hal_data->sync_err_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x1800, 0x09, &hal_data->tx_toggle_pdo_os, &hal_data->tx_toggle_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x11, &hal_data->count_pdo_os, NULL);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x12, &hal_data->latch_pdo_os, NULL);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x6000, 0x14, &hal_data->period_pdo_os, NULL);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x7000, 0x01, &hal_data->ena_latch_c_pdo_os, &hal_data->ena_latch_c_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x7000, 0x02, &hal_data->ena_latch_ext_pos_pdo_os, &hal_data->ena_latch_ext_pos_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x7000, 0x03, &hal_data->set_count_pdo_os, &hal_data->set_count_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x7000, 0x04, &hal_data->ena_latch_ext_neg_pdo_os, &hal_data->ena_latch_ext_neg_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid, 0x7000, 0x11, &hal_data->set_count_val_pdo_os, NULL);
bkt
Last edit: 5 years 8 months ago by bkt.
- db1981
5 years 8 months ago #199804
by db1981
the custom driver for the el5151 needs to be modified. It has to check for the revision of the card and then use the corespondending pdo mapping.
If you look at this:
and here:
beckhoff changed :
0x1c32, 0x20 to 0x6000 , 0x0E and
0x1800, 0x09 to 0x6000 , 0x10
sizes are the same...
so if you are firm with this, you can change these 4 lines, compile and test it.
!!!{0x1c32, 0x20, 1}, // Sync error
!!!{0x1800, 0x09, 1}, // TxPDO Toggle
and here:
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid,!!! 0x1c32, 0x20!!!, &hal_data->sync_err_pdo_os, &hal_data->sync_err_pdo_bp);
LCEC_PDO_INIT(pdo_entry_regs, slave->index, slave->vid, slave->pid,!!! 0x1800, 0x09!!!, &hal_data->tx_toggle_pdo_os, &hal_data->tx_toggle_pdo_bp);
beckhoff changed :
- bkt
5 years 8 months ago #199815
by bkt
I'm not very ... but I don't see any other chances for my incremental encoder .... is there any?
db1981 wrote: so if you are firm with this, you can change these 4 lines, compile and test it.
Time to create page: 1.632 seconds
