Ethercat HAL driver
11 months 2 weeks ago #338199 by ruediger123
Replied by ruediger123 on topic Ethercat HAL driver
Hello,
I try to integrate the security plc from Sick Flexi Soft via ethercat but I get the message that bitLen only allows 32 bits.
Are the restrictions limited to Linuxcnc-ethercat or do they also apply to the IGH ethercat-master.
11 months 2 weeks ago #338205 by Hakan
Replied by Hakan on topic Ethercat HAL driver
The array data types are not implemented in linuxcnc-ethercat.
Not 100% sure about IgH Ethercat master.
11 months 2 weeks ago #338211 by endian
Replied by endian on topic Ethercat HAL driver
Translate it as complex . Import it as s32 or u32.. Then create simple component to cut it a pieces... Simple and effective
7 months 3 weeks ago #343896 by mrgksworld
Replied by mrgksworld on topic Ethercat HAL driver
Hello,
Did you manage to integrate Sick Flexi Soft Safety controller with IgH Ethercat?
I can set the Sick safety controller in operational mode but can not able to get the data exchange correctly. Probably configuring the pdo incorrectly.
Time to create page: 1.714 seconds
