Ethercat HAL driver
5 years 2 weeks ago - 5 years 2 weeks ago #223397 by db1981
Replied by db1981 on topic Ethercat HAL driver
hal pin names are missing.
<pdoEntry idx="6000" subIdx="1" bitlen="1" halType="bit"/>
<pdoEntry idx="6000" subIdx="1" bitlen="1" halPin="inputxx" halType="bit"/>
Last edit: 5 years 2 weeks ago by db1981.
5 years 2 weeks ago #223401 by rollfree
Replied by rollfree on topic Ethercat HAL driver
If you are not interested in the content, then it should not even have a halType.
For example:
<pdoEntry idx="6000" subIdx="1" bitlen="1"/>
5 years 1 week ago #223649 by Sviper
Replied by Sviper on topic Ethercat HAL driver
Hello,
here the files for a 3 axis system
Frank
Hello cgc,
can you share your Twincat Projekt for the config of the EL6751 and drives?
5 years 1 week ago #223681 by ASKoskov
Replied by ASKoskov on topic Ethercat HAL driver
Now Linuxcnc is running, but the module does not respond when the signal changes. Where did I go wrong? In hal meter lcec.0.BK1120.Out_220_01, the value changes.
5 years 1 week ago #223690 by db1981
Hello,
what do you mean with "In hal meter lcec.0.BK1120.Out_220_01, the value changes" ?
Does the slave reach ethercat op state?
5 years 4 days ago #224538 by CORBETT
Replied by CORBETT on topic Ethercat HAL driver
I have been off of here for months as have been super busy with work… but have been working on another small retrofit… just never enough time.  The forum has been updated since I was on here last time...
@db1981
Hey man thanks for getting back on here for the last few months and helping out.  I know you were not around for a bit and good that you are back helping.  I always like the say thanks to the major players that help as it is always appreciated….
I remember you having a setup using a Beckhoff EM7004 and I finally acquired one last year, but unfortunately it was not working.
Robert
Time to create page: 3.621 seconds
