Ethercat HAL driver
5 years 1 month ago - 5 years 1 month ago #221191 by udoS
Replied by udoS on topic Ethercat HAL driver
@yrodriguez
1. You have data on the RPi4;
2. You want this data make available to PC-Ethercat-Master and ultimately to Lcnc ;
SO: some how you need the RPi to become a slave ; I told you one way to do that ;
Then you can read the data through the master into the HAL.
For that you need a component to attach the slave to the Etherlab Master, but that is available.
Hope that helped or else please give more info's / details about your setup or intensions.
best rgds   udo
Last edit: 5 years 1 month ago by udoS.
5 years 1 month ago #221192 by udoS
@db1981
the Bausano slave is a legal expansion board for the raspi.
They are building a whole range of low cost ethercat cnc boards.
Just have a look
5 years 1 month ago #221194 by udoS
Now there is also a soft-plc available running on linux-PC and RPi3/4 that has a Ethercat Master.
From there it just takes a rt-plugin (shared memory with semaphore) to have any data from plc into HAL;
Nothing illegal about it.
Best rgds.   udo
5 years 1 month ago - 5 years 1 month ago #221196 by yrodriguez1234
Replied by yrodriguez1234 on topic Ethercat HAL driver
I going yo explane that a have mount.
1. PC with LCNC 2.8 and ethercat Master working.
2. A raspberry pi 4 with LCNC 2.8 and ethercat Master working.
My problem is when a conect de PC with rpi through ethercat, the PC does not reconize de rpi as ethercat slave.
I need reconize rpi 4 like slave to send information from a hal component on rpi yo a hal component on PC
I readed SOES from Github but I don't know how use it to solve my question.
Thanks.
Last edit: 5 years 1 month ago by yrodriguez1234.
5 years 1 month ago #221200 by db1981
Replied by db1981 on topic Ethercat HAL driver
you can only talk beetween ec master over an bridge interface, but that hat not be done yet on linuxcnc.
To get your pi as an slave you need an extra piece of hardware, (like the bausano udoS showed, it has an ethercat stamp on board) .
But to get your information from linuxcnc on your pi to the ec-slave board, you have to code an own component / interface driver.
If your use case is not realtime critical i would implement my own tcp communication layer in an c-comp.
5 years 1 month ago #221202 by yrodriguez1234
In my case is not realtime critical I could test your c-comp.
Time to create page: 0.242 seconds
